Technics su v303 power dead problem & i want service manual in english
  • Audio Player... Master
  • 15,557 Answers
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
marsrover
  • 682 Answers
SOURCE: Problem with amplifier Technics SU-V500
it is relay control the output you can changed in near electronic service center.
Posted on Mar 10, 2008
robotek
  • 1512 Answers
SOURCE: technics su-v45a
Hi ferrariman
For sure, even though a manual is a bit hard to find for free, we may be able to help you solve the problem. I have worked on alot of technics amps over the years. What is happening to the amp?
regards
robotek
Posted on May 20, 2008
  • 130 Answers
SOURCE: Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Posted on Dec 05, 2010
SOURCE: su-v55a technics amp cuts off when volume up to 2
I got a problem for su-v55a technics one speaker is not playing
Posted on Mar 03, 2011
Hi I am looking for manual for my technics su-d7000 equalizer. Plz help
try to use this manual which includes schematic diagram also:
TECHNICS SU C7000 SM Service Manual free download schematics eeprom repair...
If you could not use this please ask this question again.
Thanks
May 14, 2016 | Technics Audio Players & Recorders
Technics SU-G75 owners manual download
http://www.manualslib.com/manual/926367/Technics-Su-G75.html?page=2#manual Technics SU G75 Service Manual Page 2
Sep 23, 2015 | Technics SU-G75 Amplifier
How do I change the power switch on my Technics SU 2800 Amp the power switch does not hold on works if held manually but relkeasing the button makes the power stop
First of all, you need to find the switch. The Technics of the past, is long out of business. Actually, Technics was a priority brand of Panasonic.
Aug 05, 2015 | Technics Audio Players & Recorders
On my Technics SU-G90 where do I connect the subwoofer
Some amps have a single RCA socket for a powered sub. If it has not got one of these then the amp has no output for a powered sub. If so then you can only use a none powered subwoofer, which will connect via the speakers of the amp, see the subwoofer manual for how to do this.
Feb 18, 2014 | Audio Players & Recorders
What could cause intermittent no power to amplifier relay (RLY551) in Technics SU-V96?
Check the relay control transistors. Check the voltage at the collector and base of this transistor. Download the service manual to your device to get more details.
May 26, 2012 | Technics Audio Players & Recorders
I do not have a problem, however I need to purchase a manual for my suvx500 amplifier.
Go to the following address:
http://safemanuals.com/user-guide-instructions-owner-manual/TECHNICS/SU-VX500-_E
There you will find both the user's manual, and the service manual for the Technics SU-VX500 receiver.
Oct 24, 2009 | Technics SUV500 2-Channel Amplifier
PCG-F540 service manual
No hay problema, yo hablo tambien castellano, perdona las falta de ortografia.
El manual de servicio no lo tengo, pero te puedo decir que hay dos maneras de aceder al disco duro del Vaio, dependendo del modelo.
En algunos tiene que remover la tapa que se encuentra a la base del portatil, esta suele ser marcada HD, y se encuentra cerca de la tapa de la memoria RAM. Este deveria de ser su caso.
Aqui esta el diagrama de su ordenadora.
El HD es la pieza 24, y se inesta en el HD Slot, indicado con G:
Oct 19, 2008 | Computers & Internet
Technics su-v98. Powers on but no sound can be heard, not even through the headphones jack.
Make sure it is not on mute. Check rear of receiver to make sure AUDIO IN has not become disconnected. Check input selector and verify that it matches the audio source.
Apr 03, 2008 | Audio Players & Recorders
205 people viewed this question
 Grubhead
Grubhead
