EGSM 900_1800 IMEI: 352429059203112 MATERIAL: 002v2s8 Want to unblock to use vadafone sim
Hi, if you need to unlock the network, it's possible on Fastgsm.com. But in case of Nokia c101 only several networks are possible to unlock, so check if your network/country is supported.
SOURCE: imei blocked
You need to call your phone company, they have control of unblocking the IMEI code. Sorry your having so much trouble with this, hope i've helped you!
SOURCE: blocked phone through imei nokia n95 8gb
You
have to contact your service provider .
The IMEI (serial number) block on the
phone, which stops it being used with a different SIM card, this may
take up to 48hours to clear.
Please try to contact Customer Services of your
provider. They will help to get you back and running.
More info about IMEI, please click here to check:http://www.1010store.com/forum/viewtopic.php?f=2&t=180
SOURCE: I want to unblock a blocked IMEI on an apple iphone. Can anybody
you cant unblock a blocked imei due to the fact that the previous owner of your iphone decided to report the iphone as stolen and get it blocked (which i am suggesting that the phone is stolen). If you try to call whoever company then they wouldn't be able to give you any information on WHO blocked it due to data protection act. If you're the person who blocked it, you can simply call in and ask to unblock it as long as you give proof that you're the owner. Hope this helps.
SOURCE: the phone is blocked and imei is blocking some
The unique IMEI code allocated to your phone has been blocked because your phone has most likely been reported as stolen or using a fake/illegal IMEI.
If it is not the case, and if you are the original owner and you are using the original IMEI as indicated on your device identification label, contact your Mobile service provider and ask them how to remove this IMEI number from the worldwide shared IMEI blocked list.
Hope it helps: let me know how you go.
