Question about Coffee Makers & Espresso Machines
I have Mokita Super Inox espresso and I'm looking to buy Cappuccinatore attachment for it. - Need to know what will work with machine
I have 2004 Mokita Super Inox - never used. I would like to buy milk frothing attachment (Cappuccinatore) - I do not know which type will work with my espresso.
SOURCE: saeco milk island - no froth
Molly -- re: position of grey plug. I don't think this makes any difference at all. The key issue is to make sure those two slots are clear of debris or moisture. One month on and I have continued to achieve thick frothy milk purely from rinsing the milk island parts under a running tap, leaving them to dry, and then giving a short sharp blow to the two slots in the valve before reassembling.
Good luck
Guest with Solution 2
Posted on Apr 20, 2008
SOURCE: milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Posted on Apr 30, 2009
SOURCE: the steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Posted on Feb 14, 2010
Testimonial: "Thank you very much for the advice. I adjusted the black tube and the frothing is back!"
  • 21 Answers
SOURCE: Nepresso aeroccino doesn't spin fast enough to froth the milk
The company will tell you to turn upside down for 24 hours to reset. I did this but it did not work. Try turning upside for aeroccino upside down for 24 hr. You do not need to do this to the base. They told me if this does not work, I need to buy a new one. I hope you have better luck. I am on my third one. you may be covered under warranty- call Nepresso soon..they cover them for about 1 year. Good luck
Posted on May 08, 2010
SOURCE: EAM3500S will not froth milk ?
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Posted on May 02, 2011
Where J can buy cappuccinatore
You can usually buy the kits from most online dealers but if you just need the cappuccinatore I have some for $5 plus shipping. saecosmart@yahoo.com
Feb 07, 2011 | Saeco Royal Professional Espresso Machine
I need to buy a vev replacement rubber seal for my stainless steel stovetop espresso machine
go to http://vev-vigano.com/
then click on the small envelope on the upper right hand corner and email them with your question
May 20, 2010 | Vev Vigano Kontessa Inox 6-Cup Espresso...
I HAVE A GRIMAC MACHINE CAN I PUT A CAPPUCCINATORE?
Their is a cappuccinatore for every machine that have a steam wand
Dec 04, 2009 | Saeco Royal Professional Espresso Machine
I need a rubber washer that seals a Vev Vigano Vespress Inox 14-Cup Espresso Machine
Nov 10, 2009 | Vev Vigano Vespress Inox 14-Cup Espresso...
Cappuccinatore does not draw milk
Hi
There should be a little knob on top of the cappuccinatore. It is what causes the milk to flow up the tube. When it is steaming, rotate the knob slowly until the milk starts to flow up the tube. You can fine tune the knob to get the best foam.
If you are missing the pin that has the knob on it, there will be a small hole in the outside top of the cappuccinatore. If you don't have hole and a knob, it is broken off and you need to replace the cappuccinatore
Oct 19, 2009 | Saeco Royal Professional Espresso Machine
No Hot Water when you press the button
I uploaded a file on descaling your machine at this site groups.google.com/group/espresso_worlds moz-screenshot.jpg
Mar 20, 2009 | Saeco Royal Professional Espresso Machine
I am looking for a replacement cappuccinatore automatic milk pin
check out the enclosed link:
http://www.cafeparts.com/SearchProducts.asp
Let me know if this helps.
Have a great day!
Mar 06, 2009 | Saeco Royal Professional Espresso Machine
Miele cappuccinatore 06229800
My Miele cva4075 is not frothing the milk. Also, how do I clean the cappuccinatore?
Oct 25, 2008 | Miele Cappuccinatore insert - GCEO -...
Saeco cappuccinatore not taking milk, instead blowing some steam into milk
Try this, the valve diagram shows that you twist the knob, but you left it up and down to adjust the flow. You could also check that the container you have the milk in, is lower in height than the cappuccinatore to help it siffin the milk up from its container. Make sure the cappuccinatore is fitted correctly pushed in fully and half fill a cup with milk and pull the valve adjuster up a small amount and push the button. It should start pushing steam out the cappuccinatore and then within a few seconds it should start siffining milk up the tube.
Cyril
Sep 27, 2008 | Saeco Royal Professional Espresso Machine
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Coffee Makers & Espresso Machines Logo
153 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
