Question about Gestetner Office Equipment & Supplies
Wrinkled creased paper
Adonis 2045
  • Gestetner Master
  • 1,294 Answers
Check the fusing unit lower pressure roller and the pressure roller cleaning roller.Is dirty.
Posted on Apr 23, 2013
How to remove wrinkles from polyester table cloth?
After unfolding a new tablecloth, you'll quickly notice those pesky creases. Even after washing and drying the tablecloth, they may still be there and with wrinkles too. Before you iron a polyester tablecloth -- which if done incorrectly may burn, melt, stain or shrink the fabric -- try rewashing and drying it in a manner that reduces wrinkles and helps get rid of creases. Then, iron only if necessary.
Read more : http://www.ehow.com/how_10054670_creases-out-polyester-tablecloth.html
Jun 23, 2014 | Furniture
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
Lexmark c540n creasing paper
First, check the quality of the paper you are using. The fuser will heat the paper, it tends to give a wrinkled effect on the paper. Try a new ream of good quality paper, and if it still does the same, the fuser itself might be causing the issue and you might need to replace it. For further details, please contact our Technical Support Hotline on 1-800-539-6275.
Nov 24, 2012 | Lexmark C540N PROD SPECS TBD Printer
How can I stop the paper from jamming
Be sure to load paper very carefully, removing and discarding any sheeets wrinkled or creased. Check the paper path, looking especially for paper dust or scraps of paper from earlier jams. Check the rubber sheet pickers as they may be worn or dirty. Check the paper path as thoroughly as possible, again looking especially for paper dust or scraps of paper from earlier jams.
Sep 08, 2012 | Canon imageRUNNER 2000 Copier
The printed page comes out creased from the top left of the page to the bottom right.
Download this manual >> http://www.mediafire.com/?i0y9iqnqu79ppcj Go to page #203(6-15) Paper Feeding problems (wrinkles or creases) and follow the troubleshooting steps.
Note: PDF manuals require the Adobe Acrobat Reader for viewing and printing. http://get.adobe.com/reader/
Sep 03, 2011 | Brother HL 5140 Laser Printer
Wrinkled copies
Fuser unit is about the only thing in this model of printer that WILL cause wrinkling/creasing of the paper. So most likely, yes you are going to need to replace the fusing assembly.
Part# LU0214001K
About a $179.00
The vendor I use is precisionroller.com
Good Luck
Mar 04, 2010 | Brother Multi-Function Center MFC-8870DW...
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Printer
High moisture content in paper,
or fuser (ie hot bit rear) needs replacement the orange fuser pressure rollers are wrinkled or worn.
Jan 09, 2008 | OKI C3200n Led Printer
19 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
