Question about Kenmore Elite 45986 Front Load Washer
Elite 45986, door lock mech.
The first issue I had was the door did not unlock, machine was still under warrenty. replaced door lock mechanism, a few months later the door would not lock at all.
Is this a product defect of this machine? There are times when the door lock will lock and codes flash, I unplug then plug back in and it works well. Am I missing a reset button somewhere or is this machine just haunted......lol
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Washer error code dlf
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Dec 01, 2011 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite QuietPak9 front-end loading washer. Every 40 to 80 loads I get a DLF or door lock failure code. I have to unplug power, remove lid and and press in pink wires that go into a green...
Kevin
Oct 28, 2011 | Kenmore Elite 45986 Front Load Washer
Hi! We have Kenmore Elite he3t. We noticed water in the washer today after a complete cycle so we ran the rinse and drain command on it. I tried to begin a new load on a normal wash cycle and it will...
Kevin
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
We have a he3t washer that is showing an error message of F DL code? actually, it is an he4t
Kevin
Jul 15, 2011 | Kenmore Elite 45986 Front Load Washer
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
WHAT IS DU?
DU is door unlock error - A Door Unlock Error occurs if the door cannot be unlocked. It will try to unlock the door 6 times before displaying the error.
Solutions -
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
  • May 19, 2009 | Kenmore Elite 45986 Front Load Washer
    Kenmore front loading washer
    brand new and you changed the latch mech.? door latch or lock asm.? DU is door unlock error, it tried to unlock and cant. usually replace lock asm (inside machine) for this problem. may have latch out of alignment.
    Dec 01, 2008 | Kenmore Elite 45986 Front Load Washer
    Front Loading washer Kenmore Ht3
    Here are the steps to unlocking the door manually if clothes are still in the machine.
    1.Unplug machine
    2.remove bottom panel
    3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
    4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
    5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
    6. You may now open the door.
    This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
    Nov 15, 2008 | Kenmore 46462 Front Load Washer
    Kenmore elite HE 3t - error code F dU and door is locked
    Just in case there is a pull string with a loop, all plastic under the latch, need to pull the toe panel off and reach up inside the right, unplugged of course until you feel the switch. a pull latch is below the switch incase this happens and hats off to all star/ a serial error or a faulty switch is most of what causes this to start.
    Jul 29, 2008 | Kenmore Elite 45986 Front Load Washer
    HE5t Kenmore Elite
    non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
    May 30, 2008 | Kenmore Elite 45986 Front Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    Sal De
    fordexpert
    Whirlpool
    Whirlpool
