Kyocera km 4050 showing error code cfb31 how to clear it
KYOCERA KM 4050 SHOWING ERROR CODE CFB31 HPW DO I CLEAR IT.
  • Anonymous Mar 21, 2014
    c6030
This error has to connect the connector (red, green, white, black, black) in the wrong place in panel. yc1 - yc9
Posted on Jun 03, 2013
    Habit-Forming:
  • 47 Answers
Hello its me kagimu again you are saying your machine is showing error code cfb 31 here is a solution that problem is a control panel problem but it is simple just get that panel change the memory of that panel and put that one you found on that machine trust me that error code problem will go away OR Try to and get another firmware mainly its better you get a firmware produced in 2007 and installl it.
Posted on Jan 22, 2015
SOURCE: KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
Posted on Jun 12, 2008
  • 43 Answers
SOURCE: error code C-6 for kyocera km 1500
Fuser error,
may have either a blown lamp, blown thermo fuse or faulty thermistors, but more then likely a combination of at least two.
Posted on Mar 02, 2008
sir fixalot
  • 146 Answers
SOURCE: Kyocera Copier Password (KM-4050)
The factory default password should be 4000. If thast doesn't work you will have to reset or display the admin password in service mode.
To enter service mode hit the ststus button and then type 10871087. Scroll through the menu with the * and # keys. If you make changes in service mode and do not know what you are doing you can cause the copier to permanently fail.
Posted on Nov 18, 2008
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
fsantello
  • 4 Answers
SOURCE: Error Code 2102
Change the SMTP port from 25 to 587
Posted on Aug 20, 2009
My kyocera 4050 is showing cfb31. How do I solve the problem?
the error is a system error if the following error code is displayed. When an error has occurred, clear the error by turning the main power switch off then on.
These error type should be reseted by restarting the machine
CF1XX, CF2XX, CF3XX, CF4XX, CF5XX, CF6XX, CF7XX, CFAXX, CFBXX, 0xFBXX
Best regards,
Marius
Nov 14, 2016 | Kyocera Km-4050 With Feed, Finisher, Bank,...
How can i fix error code cfb31 which appears on my kyocera km-4050 printer
Just generally CF-B31 firmware errors can be caused by a bad CODE DIMM, main board, or operation panel.
Try loading new firmware ...
Aug 21, 2015 | Kyocera Km-4050 With Feed, Fax, Finisher,...
How i can solved the error code cfb31 for km 5050
communication problem between the Panel PCB and the controller PCB.
the lcd displays go bad in these units.
Dec 23, 2014 | Kyocera Office Equipment & Supplies
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
Error cfb30
Try upgrading the latest firmware
Aug 24, 2014 | Kyocera Copystar Fax System M Km-5050...
1,797 people viewed this question
k24674
