Question about U.S. Robotics (9107) Router (USR9107A)
Vpn connection I tried to connect to my institutional VPN and keep getting error message 800. Please advise.
    Scholar:
  • 145 Answers
That error means it was unable to connect. Can't find vpn server or security was wrong. Are you running a firewall? If so, open port 1723 and try again or shut it down while testing.
Posted on Mar 12, 2009
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
VPN connection error
1) you are dialing the wrong number.
2) make sure you have good connection.
3) If using VPN, make sure the port 1723 and IP Protocol 47 (GRE) are opened.
Apr 04, 2008 | Televison & Video
I have tried to connect to my work server via vpn but get error message 800 everytime. 'Error connecting to VPN connection Connecting to .................. using ?WAN Miniport (L2TP)?.. Error 800. The...
First thing to try is making sure you have the latest firmware on the router. If you have not logged into it before you need to type http://192.168.2.1 in your browser address bar and log in when prompted. The router by default does not have a password set so it might be worth setting one in system settings. You should find on the menu an option to update the firmware. Read the screen should guide you how do this. If the firmware is up-to-date and you still have a problem try disabling your firewall on the pc to see if it's getting in the way. Don't leave the firewall off if you find it's causing the problem you just have to work out how to configure it to allow the traffic out. The route should allow this traffic out by default.
Dec 02, 2010 | Belkin (F5D8231-4) Wireless Router...
Every time i go to oovoo it keep getting this error Error 101 (net::ERR_CONNECTION_RESET): Unknown error.
DON'T USE GOOGLE CHROME ITS FULL OF TROJANS!!! WINDOWS DEFENDER ON MY MACHINE DETECTED IT!!!! TRY FIREFOX!!!! HOPE HELPS :D
Feb 15, 2010 | Google Chrome
Cisco VPN Client Error
Hello
Try to switch off the Cisco VPN Stateful firewall.
Apr 19, 2009 | Computers & Internet
I have VPN connection, but it is not connecting in to VPN, but connecting broadband only. please help me how to configure VPN network from Broadband. Total Treasury department in Srikakulam District using...
there might be some problems and you have to go through them.
--> check the cable
--> check the vpn connection settings
--> check the server name
--> check the user name and password (it should be same as of your system in office
--> make sure your computer is on at work
i hope this will help you
if none of them work then the easy way is to make other connection that will definitly do
Mar 24, 2009 | Sony VAIO FX150K Notebook
Want to make a network connection between two office 800 meters.
Buy 2 DIR 130 VPN routers and connect the two office networks via LAN-LAN VPN tunnels.
If you have the time and skills you can build two IPCOP firewall routers and connect via VPN tunnels (http://sourceforge.net/apps/trac/ipcop/wiki)
Mar 03, 2009 | D-Link (DIR-130) Router
Error message
The VPN you want to connect to has not given you permission to connect. Check with the administrator on the other end.
Oct 29, 2007 | Computers & Internet
Not able to connect to server
The software vpn probably will not work.
Is the vpn tunnel up? Can you ping the IPO? what subnet is the pc?
Oct 22, 2007 | Avaya 4610
Vpn error. 800
Resolutions: 1) if you have firewall, open TCP Port 1723, IP Protocol 47 (GRE). 2) make sure you can reach the VPN server by using ping. Sometimes, poor connection can cause this issue too. 3) You may need to updated firmware on a router or firewall if other OS (win9x/nt/me/w2k) works except XP. 4) The VPN server may not be able to get IP from DHCP for the VPN client. So, you may want to re-configure VPN host networking settings. For XP pro VPN host, go to the Properties of the VPN>Network, check Specify TCP/IP address and Allow calling computer to specify its own IP address, and uncheck Assign TCP/IP addresses automatically using DHCP. 5) Make sure no other secure software blocks your access, for example, if you use Norton secure software, you may need to add the remote client's IP so that the client can access. 6) If your VPN running on a Windows RRAS with NAT enabled, you may want to check the NAT settings. 7) If you can establish the VPN from the desktop at home but not from the laptop. Make sure no security software like Microsoft OneCare software that blocks the GRE.
Oct 01, 2007 | Acer Aspire 5100 Notebook
U.S. Robotics (9107) Router (USR9107A) Logo
208 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
