Question about HP iPAQ hw6515 Pocket PC
Turn it on
How can i turn on my hp6515, because when i turn it on, appear a msg saying that tap the screen to set up your pocket pc
    Problem Solver:
  • 5 Answers
Skipper360 has it nailed, though I have seen an issue where I turn on my 6515 and it comes up with the alignment screen, a quick soft reset and it will reboot back to its normal configuration.
Posted on Aug 24, 2007
  • 58 Answers
You need todo the setup first to use this unit. Tapping the screen with the stylus its calibrated the unit so you can use the full screen and recognizes the size of the screen. Thats all you need SETUP 1st. Then start enjoying your unit.
Posted on Aug 04, 2007
    Problem Solver:
  • 16 Answers
Here is the page to download a user manual: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=179111&taskId=101&prodTypeId=215348&prodSeriesId=501209#0 The screen you speak of is an initial setup screen, if you use the stylus and tap on the screen where the cross is. this will get you started using the device.
SOURCE:
I reset my i-mate pdal phone,but after that when the phone restarted then it said tap here firmly to align the screen,i did it thousand times but nothing happen,what can i do now?
tap the screen at target for a moment again & again.if align screen disappears.time & date setting option will appear on screen.set these.after that window will be installing.it takes few minutes.i hope after this phone will be started.
Aug 08, 2010 | i-mate PDAL Pocket PC
I have a i-mate jama Pocket PC, yesterday it turn off due to low battery. Today I recharge it but it hang on align screen message..... I have tried several times but all in vain...
you should reset your phone.reset code is 1234.after that "align screen" shows
tap the screen at target for few moment untill align screen does not go.it takes several attemp.after align screen disappear time & date setting option appear.set it.after this window will reinstalling.it takes few minutes.after this phone will be started.
Sep 26, 2009 | i-mate JAM Pocket PC
My i-mate pocket pc screen does not get aligned
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
May 27, 2009 | i-mate Pocket PC
I cant get it to work!!
May 24, 2009 | Acer n35 Pocket PC
I can't make my IPAQ pass the align screen
Replaced LCD touch screen in Australia.  Cost $95.00 AUS Thanks for Fixya help you where really great.
Feb 12, 2009 | Compaq iPAQ H3955 Pocket PC
Screen is locked
Mine hp ipaq also froze up, but I tapped the screen until they moved around all in alignment, and I got the basic things back (my programs, Media Player etc. but I can't sync it with my computer. It doesn't recognize the name of my handheld.
Aug 04, 2008 | HP iPAQ HX2755 Pocket PC
Xda mini S Pocket PC problem
your phone is being reset if the situation is like that. get your pen and push the button beside the charging socket and press the power button also simultaneously.
May 22, 2008 | O2 Xda II mini
I urgently need help
your pocket pc having back up battery power when it get loss the system will loss the data what you have stored and need to restore the programs. to avoid this problem don't let it deep discharge. now you need to tap the sceeen and system will re install the programs what it have emmbedded.
Feb 21, 2008 | i-mate Pocket PC
Initialize my Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e330 or e310. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e330 Pocket PC
When you initialize your Pocket PC, the factory default values are reset to the status as when you originally purchased the Pocket PC e740. NOTE: When you initialise your Pocket PC, all data stored in the memory is deleted. Your Pocket PC's initially installed programs are not deleted. Before initialization your Pocket PC, remove all storage cards. To initialize your Pocket PC, please follow the steps: Turn off the power Press the power button while pressing and holding the reset switch with the stylus. Then release the power button When a screen appears, release the reset switch When initialization is completed, the Welcome screen appears. Set up the system according to the screen as in the case of startup procedure.
Sep 08, 2005 | Toshiba e740 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
96 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
