Question about Sony MDX-65 6-Disc MiniDisc Changer
Audio system in vw golf sport 06 showing cd error service
Hi ! my system has no sound on radio! powers up, Display showing cd error plus service .Hope someone can HELP. Yours faithfully.
2 Suggested Answers
  • 8 Answers
SOURCE: Hi My VW Golf radio is bust! It switches on and
past its day, get a new one they arnt very expensive these days
Posted on May 01, 2009
My vw golf tenacity battery went flat replace now my radio is blocked on safe mode and showes two
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your VW service centre and get them to enter this code for you.
Mar 29, 2013 | Volkswagen Car Audio & Video
Anyone have the 2001 VW Golf speaker wire colors?
If your Golf is the premium sound model here is the list:
2001 Volkswagen Golf Car Radio Wiring Schematic for Monsoon Audio
Car Radio Battery Constant 12v+ Wire: Plug #3, Pin #7
Car Radio Accessory Switched 12v+ Wire: Plug #3, Pin #4
Car Radio Ground Wire: Plug #3, Pin #8
Car Radio Illumination Wire: Plug #3, Pin #6
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Plug #2, Pin #5
Left Front Speaker Negative Wire (-): Plug #2, Pin #6
Right Front Speaker Positive Wire (+): Plug #2, Pin #3
Right Front Speaker Negative Wire (-): Plug #2, Pin #4
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Plug #2, Pin #7
Left Rear Speaker Negative Wire (-): Plug #2, Pin #8
Right Rear Speaker Positive Wire (+): Plug #2, Pin #1
Right Rear Speaker Negative Wire (-): Plug #2, Pin #2
Signal for Anti-Theft Alarm System Wire: Plug #3, Pin #1
Data Link Connector (DLC) K-Wire: Plug #3, Pin #3
Battery Supply Constant 12v+ Wire for Anti-Theft System (SAFE): Plug #3, Pin #5
CD Changer Data In Wire: Plug #1, Pin #13
CD Changer Data Out Wire: Plug #1, Pin #14
CD Changer Clock Wire: Plug #1, Pin #15
CD Changer Constant Battery 12v+ Wire: Plug #1, Pin #16
CD Changer Control Signal Wire: Plug #1, Pin #17
CD Changer Ground Wire: Plug #1, Pin #18
CD Changer Left Line Out Wire: Plug #1, Pin #19
CD Changer Right Line Out Wire: Plug #1, Pin #20
May 18, 2010 | Car Audio & Video
How do I unlock a 2005 VW Golf Monsoon Radio thats says SAFE?
I had a 95 that had this problem when I got it. I had to remove the radio, get the numbers off it, and the VIN and call a dealer to get the code for it. Don't let a dealer tell you, you have to bring it in unless you don't know how to remove the radio. When they run the radio serial# and the VIN it will give the code, or show up as an error if they are not a match.
Dec 02, 2009 | 2005 Volkswagen Golf
Vw sat nav problem
There may be a setting somewhere to define your 'home' position. It will probably default to this location as standard until you find the setting and reset it to your own postcode/home address
Jul 07, 2009 | Car Audio & Video
HARMON KARDON RADIO 06 STREETGLIDE
06 units did not have the audio circuit vibration mod installed. Unit needs to go under a microscope to isolate the bad component or solder joint. www.ironcrossaudio.com can help with the repair.
Apr 05, 2009 | Harley Davidson 426290 AM/FM Radio
Apr 03, 2009 | Sony MDX-65 6-Disc MiniDisc Changer
Radio won't play, display shows only a code of FB-1
Maybe the code error are F 61 for a panasonic sistem that code means bad audio amplifier
Jan 20, 2009 | Audio Players & Recorders
VW Radio unlock code
i need to find the code to get my radio off of safe mode for a 1998 volkwagen golf?
Jun 24, 2008 | Car Audio & Video
Sony MDX-65 6-Disc MiniDisc Changer Logo
1,038 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
