Question about Sony Lamp For The Kdf E50A12U Rear Projection Tv
When i turn my tv on it goes of straight away and keeps flashing red can you help
I have bought a new lamp for my tv it is a XL-2400 TV LAMP which has been put in but there is no picture just flashing red light
    Top Expert:
  • Sony Master
  • 75,311 Answers
After replacing the lame, the lamp time should reset. Otherwise, TV won't start. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you check the site in Timeslide option, which can be selected from the dropdown list at the top left side of the display window, it will make search easy.
Posted on Apr 23, 2013
  • 1694 Answers
SOURCE: sony xl-2100u lamp
Front Lamp Cover Door warps slightly, replace door = cost about $5.00.........has become a common problem Sony and others.
Ask Andrews Electronics for the part # of door for your Model.
...................................................................................T.
Posted on Mar 05, 2008
jerryg50
  • 1689 Answers
SOURCE: No Picture - Lamp Indicator Blinking
This may be the main power supply, or the lamp supply. This is providing that the new lamp is okay.
The service tech will swap out the modules to service the set.
Jerry G.
Posted on May 17, 2008
welcomejee
  • 10594 Answers
SOURCE: REPLACED LAMP WITH XL2400 AS REQUIRED
3 time blink shows that Lamp Cover is not fixed properly. Please check Lamp Cover and make sure its fixed securely.
Posted on Mar 25, 2009
  • 80 Answers
Refer to your owners manual on lamp replacement. Remove the old lamp and look at it. If it looks "blown" (like a flashbulb) then it is defenitely defective.
Posted on May 21, 2009
  • 1039 Answers
SOURCE: power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Posted on Mar 26, 2010
I need help. My Sony 50 inch tv is a 2006. The warranty ran out in June 2010. I heard a pop and then it shut off. Now the green light flashes 25 times and turns to the red lamp light. I can't reference...
Pop sound was broken lamp in tv, replace lamp to solve tv issue.
Please recheck model number as KDF-50EA10 seems invalid/ incorrect model number and nearest match is KDF-E50A10
If model number is KDF-E50A10 then required lamp part number is as follows...
F93087500 ... LAMP BLOCK ASSY XL-2400
and available with Sony Accessories Store for $200
Let me know if you have addition question or tv model number is other than above said (KDF-E50A10).
Thanks.
Mar 10, 2011 | Sony Televison & Video
I replaced the lamp but after flashing green it flashes red wat do I do?
hi,
check the lamp inserted is correct or not. also check the lamp cover, is it properly closed or not.
if its ok, just reset ur tv and the try again.
Turn on the TV. While holding down the up arrow button on the remote control, press the
POWER button on the TV. (The TV will turn itself off, then back on again.)
Release the up arrow button.
ok
Dec 22, 2010 | Sony (XL-2400) Projector Lamp for...
Try to start sony kdf-50e2000 tv and wil not start and red light keeps flashing. what does this mean?
You will have to replace the lamp which goes every 3-4 yrs depending how often used (Sony XL-2400 DLP replacement lamp).Your instruction booklet will explain this page 76. As further info I would also make sure the lamp comes with the cover which Amazon has it for a total price of around $130.
Dec 14, 2010 | Sony KDF-50E2000 50" HDTV
Tv picture and sound goes away for about one minute and then comes back. After another two - three minutes, the process starts over again, and again. Please help if possible, Thanks!!!
When the bulb goes off with the sound. The lamp is starting to fail andyou need to replace it. Wear gloves when replacing the lamp. UseXL-2400(part # F93087500) replacement lamp. For informationvisithttp://sonystyle.com/tv for US residents andhttp://sonystyle.ca/tv for Canada residents.
  1. Remove the outside lamp cover.
  2. Turn the knob counterclockwise to OPEN and pull out the cover.
  3. Hook a finger through the loop of the lamp handle and pull the handle upwards then pull the lamp straight out.
  4. Put the new lamp in its place. Mount it securely and take extra care not to touch glass portion of the lamp.
  5. Turn the knob back to CLOSE and secure the cover.
  6. Put the outside lamp cover back in its place.
  7. Turn on the TV
  8. Browse MENU>SETTINGS>SET-UP>Lamp Replacement then follow the on-screen procedure.
NOTE:Disposethe used lamp properly. It contains mercury and disposalis regulated..Contact your local authorities for proper disposal.
Sep 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Picture and sound go off for a few seconds and then come back on.
When the bulb goes off with the sound. The lamp is starting to fail and you need to replace it. Wear gloves when replacing the lamp. Use XL-2400(part # F93087500) replacement lamp. For information visithttp://sonystyle.com/tv for US residents and http://sonystyle.ca/tv forCanada residents.
  4. Putthe new lamp in its place. Mount it securely and take extra care not totouch glass portion of the lamp.
  7. Turn on the TV
NOTE:Dispose the used lamp properly. It contains mercury and disposal isregulated..Contact your local authorities for proper disposal.
Aug 23, 2009 | Sony Televison & Video
Sony kdf e50 a60 when TV is turned on picture goes off almost immedately and red light starts blinking in stand by mode.
Red light blinking is an indication of lamp problem. Check and secure tightly the following:
  1. Outside lamp cover
  2. Lamp door
  3. Lamp
If all of the above does not solve the problem, you need to replace the lamp. Let the lamp to cool for 30 minutes after unplugging. Use XL-2400 replacement lamp.
  2. Remove the lamp door.
  3. Pullout the lamp
  4. Hook a finger through the loop of the lamp handle and pull the handle upwards. Then pull the lamp straight out.
  5. Mount the new lamp securely.
  6. Reattach the lamp door. Turn the knob back to "CLOSE" and secure the cover.
  7. Put the outside lamp cover back in its place.
or visit http://www.fixya.com/support/t2631342-need_replace_42_in_sony_wega_hdtv
Aug 11, 2009 | Televison & Video
I need to replace my 42 in Sony WEGA HDTV Projection lamp KDF-42E2000
Lamp code XL-2400 is Sony part number F93087500 and it is available on http://www.partstore.com/. You may also decide to purchase the less expensive Philips Lighting lamp part number F93087500RL. Either will work for your television set.
Jul 19, 2009 | Sony Office Equipment & Supplies
After installing the XL-2400 Lamp unit. This is the blub and housing. I turned the TV on and after a few moments the tv turned off and on the front of the tv where the power light is it is flashing red.
Please make sure lamp cover is reinstalled securely after replacement of lamp in TV.
If lamp cover is not fixed properly, TV wont power up and red light will start blinking.
Jul 16, 2009 | Sony (XL-2400) Projector Lamp for...
Mar 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF-E50A12U TV Swith on ok, after about 30 seconds the tv goes into standby mode, green power light on with 3 rapid red flashing lights. Any assistance appreciated
red light flashing means it can't dectect lamp housing. you can try and take it out (door on side of TV to the right hand side) and reinsert. But it probably means your lamp has blown. Replacement xl-2400 lamp is east to replace. Search ebay to buy one (about £100) and youtube has a video showing how to do it.
Dec 22, 2008 | Televison & Video
Sony Lamp For The Kdf E50A12U Rear Projection Tv Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
