Question about Mitsubishi WS-65807 65" Rear Projection Television
Mitsubishi ws 65807 RED CRT
MITSUBISHI WS 65807 Had recently repaired the smudged colors and arked picture with a set of sanyo stk-392-570 worked great for a couple of months.. (:....... Now my red crt keeps going on and off giggled all the wires checked all connections with no effect could stay on all day or for half a movie or maybe be off for a week and be fine for a week so we watch a green picture hoping the red will come on sometime it does and sometimes will not .. anyone had this problem or have a fix or something I should check in the dark all 3 crt's are lit on the bottom by the circuit board at all times. red crt top of bulb just works when it wants too thanks
  • NITRO FISH Aug 05, 2007
    Pulled the red crt board this morning looked fine all well solderd pins resoldered anyway and replaced it.still the same no red watched if for a few hours last night with red untill it went out. Sometimes you just turn the tv on and off and its back on others times it out for days then back on for days or it fixes itself in the middle of a movie ?????????? thanks again
  • NITRO FISH Oct 13, 2007
    is there any certain solder joints to resolder they apear to be fine
I just fixed a similar problem, except my screen was red, not green. Follow your cord directly right of the tube up to the ground wire. My ground wire was a little loose. when i retightened it the screen returned to normal. the sporadicness of your problem sounds the same as mine was. I hope this fixes your problem.
Posted on Jan 14, 2008
  • 398 Answers
What I usually find on sets like that is that there is a loose solder joint on the CRT board itslef. You must get to the bottom of the picture tubes, pull off the CRT board from the red CRT and examine all solder joints on that board. Chances are one or more will be cracked, and resoldering all joints on the board should clear up your problem.
Posted on Aug 05, 2007
Add hdmi port to mitsubishi ws-65807
I doubt it as it was never designed for that kind of input, Component works best on this set and it should have only one HD input for a box marked in the menu as DTV.
Dec 13, 2012 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi ws-65807 series ... convergence going bad? i tried fixing it several times on menu: advance, the convergence red and blue ...it looks well for only about 3mins or so then goes out of sync...
It is very common on these and other sets. Your ws65807 is a V17 chassis that uses two of the Stk-392-570 convergence chips.
These are especially prone to being flaky or intermittant.
I am available here in the Market Place on Fixya to answer this and can provide in that area start to finish step by step instructions for this repair.
Parts cost would be under 30 dollars.
Let me know if you have any questions. SD TECH
Sep 26, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I have a mitsubishi ws 65807, i get trouble code 23
The problem is most likely convergence integrated circuit failure. I recommend finding a local Mitsubishi repair center.
Dec 05, 2008 | Mitsubishi WS-65908 TV
MITSUBISHI WS-65807. TV WON'T POWER ON AND PICTURE WAS NOT ALIGNED PROPERLY.
Good Day;
Your TV has "poor" connections on the Convergence IC's. Please get repaired B4 you have total part failure and more costly repair.
Good Luck, big IRISH.
Sep 28, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi ws-65807 no sound or picture
Check for coolant spill in corner of signal PC board = from leaky
CRT seal = bad CRT...........................T.
Apr 24, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
MITSUBISHI WS 65807 RED CRT OUT
It' sound like you have a bad crt, to make shure, just disconect the red crt baord and green crt board next to it and move then so you can try the red crt board on the green crt. If it does the same problem in witch I realy thought it's your video or hight voltage sounce on that board. If you get no problem well it's your crt.
I can almost garranty it's your crt.
Bob
Oct 13, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-65807 problems
You need the two convergence IC's replaced part# STK392-570. About a $300-$400 repair.
Aug 23, 2007 | Mitsubishi WS-65807 65" Rear Projection...
MITSUBISHI WS-65908 red crt going off and on
You don't have enough soder on the STK392-570 unit ! I had to re-soder mine and is OK now
Aug 02, 2007 | Mitsubishi WS-65908 TV
TV Image bending
maybe you have a magnet near it?
Feb 26, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
124 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
