Question about Neff H5642 Convection / Microwave Oven
Identify defrost button
How do I defrost. Control buttons M or P?
My wilkos own colourplay microwave is stuck on defrost how do i take it off defrost ... can someone help?
If it is stuck on defrost, you may have to replace the panel, the control board, or both.
Jul 14, 2016 | Microwave Ovens
How do I access & fix the control board buttons (ie Hi/Lo/Off light & Vent) which some how got pushed in?
Thanks Michael but the problem is the light & vent buttons got pushed in so far that I can't use the fan or light. Please help!!!!
/uploads/images/access-amp-amp-fix-control-board-34894445-1-1.jpg
Jan 21, 2015 | Samsung 2.0 cu ft Over-the-Range Microwave...
Emerson microwave not working 900 watts
The Emerson MW8999SB 0.9 cu. ft. 900 watt Microwave Oven is relatively compact, and certainly inexpensive, but doesn't skimp on functionality. We were surprised at all the options you get with this little microwave. It's only 20 inches wide, 11.3 inches high and 16.1 inches deep yet. The interior can still accommodate a regular size dinner plate or small (10-inch-square or round) casserole. Plus, there are 10 power levels, eight one-touch function buttons, six Express Cook settings, timed and automatic defrost options, and a rotating glass turntable to circulate the food for more even cooking.
We were very pleased with the performance of the Emerson MW8999SB. It did a fine job heating water for tea, cooking a couple of baked potatoes, reheating leftovers and steaming fresh vegetables. Even the automatic defrost proved surprisingly efficient, letting you enter the weight of the item(s) to be defrosted (4-100 ounces) for easy operation. Chicken breasts were almost fully defrosted after one cycle. We needed to stop and separate the food pieces to finish the defrost cycle.
The unit is styled mainly in black but has stainless steel trim around the door and control panel. The smooth touchpad control panel is attractive and easy to wipe clean. We loved the one-touch Express Cook buttons, which let you activate the unit at 100 percent power for 1-6 minutes, by pressing the corresponding number pad. We also appreciated extra touches such as the Start/+30 sec. button, which can be used to start the oven or add an extra 30 seconds each time it is depressed.
It's hard to go wrong when the functions are so simple. The only tricky part was identifying certain codes used on the display screen. When changing the power level, for instance, PL10 is displayed on the screen. Pressing the button additional times lets you toggle through the different levels. Likewise, the Auto Cook settings may need to be pressed multiple times to obtain the correct weight or portion for the food being cooked.
We were amazed that a machine costing so little also offered two-stage cooking, which lets you start cooking (or defrosting) on one setting and finish on another. All in all, the Emerson MW8999SB is an excellent value.
Pros: Touchpad controls, eight one-touch function buttons, six Express Cook settings, two-stage coking option
Cons: Limited interior capacity can only accommodate dishes up to 10 inches, no sensor
Jul 29, 2012 | Hotpoint RVM1435 Microwave Oven
When defrost kicks on in the freezer it stays on to long and defrost the food.
The defrost timer/control board is not working right... replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 25, 2010 | Microwave Ovens
My fridge is not very cold but the freezer it fine
Check the back wall or floor of the freezer section for frost. Check the freezer( evaporator) fan to see if it is running. Check the condenser coils( under the unit ) for blockage from dust. Check the condenser fan (under the unit) to see if it is running.
If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. These things usually require dismantling the freezer and other areas of the refrigerator to be checked.
You could defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with BOTH DOORS WIDE OPEN to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Aug 04, 2010 | Microwave Ovens
How do I stop the turntable while I'm speed defrosting?
If there is not a button on the control panel to turn of the table it cannot be defeated.
Eric
Dec 18, 2009 | Whirlpool MH7140XF Microwave Oven
Defrosting buttons and how to use
a defrost on the mic.
this button is a selector of power really, it cyles the heat on and off keeping the actual cooking energy to minimun, just enough to knock down ice crytals
but make no mistake it is working the same just a lower power setting,
you could do the same thing by selecting power level 2-3 for longer times
Oct 27, 2009 | Microwave Ovens
Neff H5642 Convection / Microwave Oven Logo
Top Neff Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
