Question about Harman Kardon Audio Players & Recorders
A4053 be 3895 does not work
Range rover
My 2005 Range Rover radio stopped working and the on/ off button blinks and now the screen just comes on and the logo Range Rover stays on
Sounds like your anti-theft is locked, if you do not know the code you can check with the dealer all he needs is the vin
Aug 08, 2010 | 2005 Land Rover Range Rover
2003 range rover power door locks do not work
does the roof lamp work? if not then means your Vehicle in transport mode. to have it in normal mode you need to take it to a dealer or something equivalent to have the job done by approved diag. machine
May 19, 2010 | 2004 Land Rover Range Rover
4.4 02 Range Rover.Blower only functions
it seems most likely it's the Control Panel faulty as this unit is has a common fault
Feb 10, 2010 | 2002 Land Rover Range Rover
How can i upgrade the navigation system of 2006 Range Rover sport supercharger.
You need to contact the dealer for information on ordering new software for your system.
Any Range Rover dealer can help you, just go to the parts department and tell them what you need.
Nov 08, 2009 | 2006 Land Rover Range Rover
Range rover air suspension stoped working
Range rovers are notorious for air susp issues, over the years I have had several issues. Unfortunately a lot of the time even the dealers fix these by accident. Range Rovers.net is a good site for a lot of issues, that can be checked without testbook. To start check the easy stuff. If the car is a 2003-on the compressor is under spare tire, height sensors can fail and can be checked with a voltmeter, check all air lines and valves. Good luck
Jul 31, 2009 | 2003 Land Rover Range Rover
2005 Range Rover HSE - Air Bag Trouble light on !
Airbag resets need to be taken to the dealer or someone with access to the right diagnostic equipment(unlikely) Store bought code readers will not work.
Jul 08, 2009 | 2005 Land Rover Range Rover
1995 Range Rover Land Rover Questions
the back windshield is the front windshield one just pull it front or back not up all down
hope is helps
Jamie
Oct 05, 2008 | 2004 Land Rover Range Rover
32 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
