Question about Turbos, Nitrous, Superchargers for Honda Fit
Can I put a supercharger on a Honda fit 2005 1.3
    Champion:
    Scholar:
  • 227 Answers
Why bother?
But yes it can be done..
Posted on Oct 24, 2013
Does my 2005 honda accord have grease fittings?
From the factory there are no grease fittings on any of the suspension/steering components. If any of those parts have been replaced with aftermarket parts than there is a 50/50 chance that there is a grease fitting for that part.
Oct 09, 2016 | 2005 Honda Accord
Can i put the supercharger off a 3.8 0n a 3.1 pontiac grand prix se?
Hi Jake, Your question is not very clear. If you're talking about removing a supercharger from an engine designed for a supercharger and fitting it to a smaller engine designed to operate with a supercharger, you'll need to check pressures and computer controls. If you're asking about fitting it to an engine not designed to be supercharged, it would require a full rebuild, using parts designed for the job. I say it is not a good idea, as the engine will probably blow. Both superchargers and turbochargers are air compressors which force air into the combustion chamber under pressure, meaning the engines have especially designed parts. Regards John
Jul 22, 2014 | 2000 Pontiac Grand Prix
How to get more hp out of vk56 engine
well this has good power if all is running good, but if you need more just put the next smaller then stock size tires on it and it will go much quicker or buy the supercharger for it it is a good fit to give it more power for pulling bigger loads
Jul 13, 2014 | 2005 Nissan Titan
Free mechanic advice
Check this out with performance shops as there may be an intercooler that fits straight in. You may have to get brackets in a kit or make them yourself. The problem will the routing of the intercooling hoses to and from the turbo/manifold . Front mounted intercooler are more efficient at cooling the air so the only problem I can see apart from the engineering side of fitting it is that you may have to have a speed shop with a chassis dyno reprogram the CPU to get the best performance from the cooler more dense air.
May 13, 2014 | 2005 Jaguar S-Type
Stock program put in computer of 2001 Supercharged Saleen. Running lean,
That would be right and if you continue to run it in this condition it will melt the piston tops or break rings.. Take it to a speed shop that can reprogram the CPU or fit a chip that will adjust the air/fuel mixture
Mar 18, 2014 | Saleen S7 Cars & Trucks
I want to change the GPS in english in honda fit 2005
IF you have a menu button and a mode button go in and find language . select it and scroll down to English and set and save on it.
Jan 06, 2014 | Honda Cars & Trucks
What type of fuel should i put in a 2005 grand prix? should i use regular, mid or premium? which one is best for the car?
3.8 liter V6
Recommended fuel, 87 octane
3.8 Supercharged V6
Recommended fuel, 92 octane or higher
Thank you for using Fixya
Mar 08, 2010 | 2005 Pontiac Grand Prix
Does a 3.8 supercharged v6 fit into the base model impala?
Yhea it would bolt right in, they sold them from the factory like that. There would be lots of differances though. In the long run it would be cheaper to find a doner car at a wrecking yard, so you can get the wiring harness, pcm, all of the brackets, and verious other things. If you could find a wreck car for sale localy take all of the stuff you will need then you could part out the rest and make some of your money back!
Oct 20, 2009 | 1999 Chevrolet Lumina
Improve speed
which i need to make faster. I have been looking at the peugeot jetforce moped which has a supercharger would it be possible to put a supercharger on mine?no chance....not unless its built for one....get better parts the supercharger wont do you any good. get a better exaughst,chain,gears,etc,,,
Nov 10, 2008 | 2003 Hyosung GV 125 Aquila
2005 Monte Carlo Super Charger Oil
On the supercharger snout, located immediately to the right of the coil pack mounted closest to the supercharger, is the supercharger oil plug. It is a hex nut that uses a 3/8" allen wrench.
When the engine is cold, remove the plug. You can use any item of your choice that will create vacuum such as a siphon, a turkey baster or my favorite is a squirt bottle nozzle with about a 12" line on it.
Insert your hose into the reservoir hole and remove as much of the oil as you can. If you use the squirt bottle nozzle then if the hose is long enough then you should be able to "snake" the hose down into the reservoir almost the entire length of it by pushing the end of it toward a "1 o'clock" position if you are standing directly in front of the car.
Squirt the oil into another container. If your oil is the GM supercharger oil, it is animal fat based and biodegradable and can go in your regular trash.
Refill with GM supercharger oil or any other appropriate lightweight oil specified to meet requirement for the Eaton M90 supercharger. An equivalent oil can be purchased from www.zzperformance.com.
Fill the reservoir until the fluid reaches the bottom of the fill hole threads.
As an added note, if you lose the hex nut cap for the reservoir it isn't necessary to order a new one. A 7/8" fine thread bolt will fit perfectly but be careful not to torque more than 8ft/lbs with either the nut or bolt.
Aug 02, 2008 | 2005 Chevrolet Monte Carlo
Turbos, Nitrous, Superchargers for Honda Fit Logo
48 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Charles T Nevin
Charles T Nevin
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
