Question about Singer 7422
Bobbin case pops out wehen sewing.
My singer sewing machine, the bobbin case keeps poping out when i'm sewing, i adjusted well the thread. but its the case the is giving me problem.
  • 1 more comment
  • Anonymous Apr 25, 2009
    I have the same problem. The bobbin case lifts up. the neddle hit it and breaks. What can I do?????????
  • Anonymous May 04, 2009
    my bobbin jumps up too and breaks needle... no burrs on case
  • Anonymous Mar 20, 2014
    Singer sewing machine, give me an E5 error, re-thread and bobbin, still get message.
  • 323 Answers
The case probably has a scratch or a burr on it. Take it out of the machine and examine it for burrs or scratches.If you find some they can be removed with an emeryboard and then buffed with an SOS pad to make it very smooth.
When you put it back in the machine, thread the machine and sew by turning the wheel a few times before you actually begin sewing for real.
sewman7
Posted on Mar 20, 2009
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
My bobbin on my Singer 4562 keeps bunching up the threads, can you help?
If you have the black bobbin case you must make sure you use only a good mercerised thread, there should be enough gap between the edge of the bobbin case and the silver adjuster to allow the thread to pass through, if there is not then you must slacken off the two screws and move it over a fraction.
Aug 11, 2011 | Singer 2732 Mechanical Sewing Machine
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. I cleaned the bobbin case, but now it won't sew at all; the case keeps...
unscrew the black plate that holds in the bobbin case and move it over to the left just a little bit, but make sure there is still clearance between the lower right corner of the case and the plate. The case should be able to wiggle a little, but not so loose it can pop out..
Jan 17, 2010 | Singer Inspiration 4210 Mechanical Sewing...
The bobbin case on my Singer Inspiration 4210 sewing machine keeps popping up in the back causing my thread to bunch up underneath. What is causing this? Is the bobbin case in wrong? How is it supposed...
From what I gather on other sites, your thread has to be threaded under tension.... You have to make sure you hear a click when your bringing your thread down to the bottom of the "arm". Also, I thought the bobbin case was rather loosely held in its place, I adjusted this by unscrewing the black plate and moving it over just a smidge. The bobbin is supposed to have some wiggle room, but it kept popping up and making the tiny adjustment seems to have done the trick....for now...
Nov 14, 2009 | Singer Inspiration 4210 Mechanical Sewing...
Bobbin case is popping out, and machine is birdnesting
Usually when this happens the bobbin is in wrong, replace it make sure the thread is going out the right way, make sure there is no lint or small pieces of thread around or underneath the bobbin area. Make sure you thread it with the foot up. Also make sure you are usng the right bobbin for the machine. They can easy get mxed up.
Jun 16, 2009 | Singer CE-100 Futura Computerized Sewing...
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7422 Logo
341 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
