Question about Rinnai Heating & Cooling
Rinnai Convector 516 gas heater wont start up
When I turn on my Rinnai Convector 516 the fans start & it makes clicking noises for about 10 seconds then stops. On/Off button flashes red & 2nd light on Temperature Control scale also flashes. There's no display on this model, assume Temp Control light indicates applicable error? Cleaned filters & removed front panel to vacuum dust - want to try cleaning pilot orifice but can't figure out where it is! Its getting cold - can anyone help?
Therinnaiguy
  • 1420 Answers
SOURCE: rinnai convector 404
You have a dirty pilot assembly and maybe even a bad ECO switch (safety switch). I would suggest replacing the ECO and removing the pilot assembly and clean it out.
Posted on Jun 03, 2008
johnsonr1
  • 91 Answers
SOURCE: How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Posted on Nov 13, 2009
  • 2550 Answers
SOURCE: i have a rinnai convector 406/516 unflued room
if you google your heater you can find the fault codes and print them off ,they will tell what is wrong and if you need a tech call
Posted on May 19, 2010
  • 4736 Answers
SOURCE: Evening, Rinnai Convector 417 -
There are about 8 reasons why this is happening. Rater than going into each and every one, I have included a link to an Owners Manual, that under the Troubleshooting Sections (pages 12 & 13) it will provide you with the scenario and how to solve the problem. This manual may not be the exact same one as your heater, but they all work the same and have the same problems.
http://www.rinnai.us/documentation/downloads/RHF265-1091X0101_202FTA_265FTA_Manual.pdf
Hope this helps you to further troubleshoot and solve the problem.
Posted on Apr 27, 2011
  • 1116 Answers
SOURCE: Im a gas fitter and have a Rinnai 556fdt heater
No, the reason the light comes on is the filter is obstructing incoming air and the flow is not proper. What you may think is a clean filter may actually be a very clogged filter as you can not see the micro-particulates that have built up in the pores of the filter, Replace the filter and your problem will go away. This is also a safety matter as the filter will no longer clear up those particulates and will forced them through the filter into the ducting and the air. Clean or replace your filter altogether, this is your solution.
Posted on Aug 11, 2011
506 convector rinnai
if the flame does not start at all, so just ticking from the ignitor you have a main valve problem and this is expensive replacement part and it must be done by a trained gas fitter.
May 21, 2014 | Heating & Cooling
Clicking noise Rinnai Avenger Gas heater
Is sounds like it could be the automatic ignition. If the sound only happens when you are pressing or turning the knob, I would say that is all that it is. Most gas heaters have an ignition switch under the knob. This triggers the ignition to try and spark. light the gas when the knob is depressed.
Apr 09, 2014 | Rinnai Heating & Cooling
Dear Sir after bearing 90156704 left hand bearing for convection fan for gas heater Rinnai Convector 516 TR can you please help tell where I can find it to buy it Thank you Joe
If you reside in Australia, you can call Rinnai Customer Support: National Mon - Fri 8.00am to 5.30pm EST 1300 555 545
I hope this helps you and thanks for choosing FixYa. Cheers!
Aug 25, 2011 | Heating & Cooling
How to turn off the chid lock on a rinnai
The button to the left of the economy mode is the child lock button. Push it in and hold for one second to either activate or de-activate.
Jul 26, 2010 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Nov 09, 2009 | Heating & Cooling
Need to convert rinnai convector 417 gas heater from propane to natural gas, are the nozzles available?
Rinnai New zealand conversion kit number, R1852.
VERY complicated - get a qualified gasfitter to do it.
Jun 10, 2009 | Rinnai Vent Free Gas Heater/
Rinnai Convector 404
Hi pinkinfinite,
The 404 is a great heater. I am assuming it is a Natural Gas Heater. All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this.
To clean it out internally you only need to remove the front panelling. There are two screws holding the top panel (not to be confused with the side and top). The screws are located inside the bottom grill at the front. There are also screws for the bottom grill there which you will also need to remove and probably best to remove the bottom panel that house the front feet. It should expose all the inside workings of the heater except for the pilot light and jets etc. You should be able to see the fan - it is round and looks like a filter and sits behind the vent section. Make sure you give it a good blow out - it gets all dirt and dust around it. When you do it remove both the rear filters/covers. They are mesh. Blow the top one which is the larger metal one and make sure you blow inside where it fits over to remove the dust and dirt. Same with the other one which should be plastic with mesh. Once you do this put it all back together. Make sure all wires are connected and be wary with the compressed air as it may blow the connectors off from loose fitting parts. Once you get it all back together Test it and hopefully it should work. Hope this helps. I did one the same today that was having trouble starting and it now works like a new one.
Regards
Bryan
May 06, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
