Question about Maytag MMV1153A Microwave Oven
MAYTAG mmv4205aab OVER THE RANGE MICROWAVE
BOUGHT NEW 2 YEARS AGO FROM HOME DEPOT. sTOPPED WORKING DURING COOKING-COMPLETELY DEAD. I PLUGGED IT IN TO ANOTHER OUTLET BUT NO POWER TO MICROWAVE, NO PANEL, NO CLOCK NOTHING. CAN THIS BE A BAD FUSE IN THE MICROWAVE? hOW DO i GET TO IT TO REPLACE IT? aNY SUGGESTIONS OR HELP WOULD BE APPRECIATED
  • 4 more comments
  • bottlebrush Mar 23, 2008
    magnetron seems to have gone out. It started to be noisy when cooking and got worse. Now it won't cook, when I opened the unit, the magnetron is making a lot of noise not the transformer
  • eg8mathews Jul 19, 2008
    microeave does nothing.I checked fuse box. Everything OK
  • Anonymous Jul 20, 2008
    our microwave suddenly stops no power at all. no lights nothing, after several minutes it comes on again and starts working. It also has a rumbling sound from the turntable.
  • jnjlashley Feb 02, 2009
    Same thing. Never had a problem and all of a sudden......NOTHING. Outlet where its plugged is fine. Will try your suggestion of replacing fuse if I can figure out how to get to it. Thanks. Will let you know.
  • mrsrothberg Apr 19, 2009
    I will NEVER buy another Maytag item. I have this microwave too. This same problem has happened to me TWICE. Maytag is not good to work with. I now am looking to purchase another microwave.
  • Anonymous Mar 28, 2014
    I checked to make sure the breaker didn't trip and the outlet was still hot. Is there an internal fuse or something I can check?
  • 5,911 Answers
It could easily be a bad line fuse and/or line filter. To access you will need to unplug the unit and remove the outside case. Inside the unit, where the A/C power cord comes in, there should be a small circuit card (part #237068) located somewhere with a fuse mounted on it. This is your input line filter board with line fuse. Replace the fuse, first and see if this fixes your problem. This is a 20amp appliance fuse that you can purchase at any hardware store. Make sure you place the cover back on the unit BEFORE you plug it in. It is not safe to have this area of the microwave exposed with power applied. High potentials in the 4,000 volt range are present! If the fuse does not correct your problem, the circuit card runs about $26.00. Good luck and hope this fixes your problem.
Posted on Aug 04, 2007
  • Jeff Rockwell
    Jeff Rockwell Aug 04, 2007
    In fact...Home Depot carries the fuses for this appliance in the Electrical and Lighting area.
SOURCE:
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 29, 2014 | Microwave Ovens
Maytag Microwave apprears to work but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-==-
May 17, 2010 | Maytag MMV4205 Microwave Oven
Maytag over the range microwave rattles during cooking, how do remove appliance to tighten up what is loose?
Microwave works fine. During operation there is a rattle sound. The table moves correctly, only problem is the sooud of a rattle. It appears to be on the right side, lower area.
Apr 03, 2010 | Maytag Appliances Over-the-Range Microwave...
My Maytag MMV1153BA Over The Range Micro suddenly lost power.
problem is a blow fuse inside the microwave, you need to call a appliance repair tech
Jun 28, 2009 | Maytag MMV1153A Microwave Oven
Are microwave safe egg poachers doing damage to microwave?
you are not supposed to have any metal in the microwaves for cooking something , as why the other two quit , that is probably why they quit so soon
there is some more exspensive microwaves that can work even when metal is used inside( but these are special types of microwves)
Nov 10, 2008 | Danby DMW1153 Microwave Oven
I just bought a Maytag over the range microwave 7 months ago and already the start button, timer button and a few more do not work - what could problem be??
Do you always use the vent fan when cooking on the stove top to keep steam and grease out of the controls? I always recommend that.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If it's still failing, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Maytag-authorized servicer here.
Sep 03, 2008 | Maytag Microwave Ovens
Goldstar MV1502W
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter lead sagainst the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
No power Dacor DCM24SS
I do a lot of work on Dacors / Sharps. Can you describe what you mean by "shutting off"? When it was shutting off before, was it completely dead with no display and no beeps? Was iut shutting off during a cook cycle or just while setting there or what? When it would come back on or start working again, how long did it take to come back, or how did you make it come back on?
Apr 28, 2007 | Dacor DCM24SS Convection Microwave Oven
Maytag MMV1153A Microwave Oven Logo
894 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
