Question about OKI B4350 Laser Printer
Upper cover sensor - OKI B4350 Laser Printer
My printer keeps telling me that I haven't closed the ink cartridges door
The ink catridge door sensor as been damaged.
Clean d sonsor and check sensor connecting wire
Jul 14, 2016 | Office Equipment & Supplies
Tying to find crank sensor for 2002 Cadillac Seville std 4.6 liter
This answer covers 1999-2005 Cadillac Deville, Eldorado & Seville.
Example Engine:
2002 Cadillac Seville STS 4.6L SFI DOHC HO 8cyl.
This engine has (2) Crankshaft Position (CKP) Sensors: the Upper sensor is CKP sensor B, and the lower sensor is CKP sensor A (this is included for the OBD-II DTC codes - P0385 references Sensor B = upper CKP sensor, whereas P0335 references the lower CKP sensor (sensor A)).
Both crankshaft position sensors are located in the front of the engine just above the oil filter adapter. To access both CKP sensors, jack up vehicle on the passenger side, remove the oil filter, and the oil filter adapter, including the Engine Oil Pressure (EOP) switch. See illustration.
The ARROW points toward Front of Car.
1. Upper Crankshaft Position Sensor (B).
2. Lower Crankshaft Position Sensor (A)
3. Engine Oil Pressure (EOP) switch
4. Engine Oil Level switch
The Oil Filter is the can-type object below the oil filter adapter, which includes the EOP switch. Recommend: remove oil filter with an oil filter socket/strap wrench, since it's close to the oil pan.
Aug 21, 2014 | Cars & Trucks
Paper won't load
Cke media detect sensor which is mounted inside of cleanout.
clean the sensor or replace the sensor..
1. Remove roller cover upper & roller cover lower
2. Disconnect paper sensor connector
3. Remove clean out (P/no CN727-60047)
4 remove paper sensor..
4e39f03f-171b-4929-bb03-f6046bc6541d.jpg 61e68018-3652-472c-8706-5e97150bb38c.jpg
Dec 18, 2013 | HEWLETT-PACKARD T2300 eMFP InkJet Plotter...
Location of camshaft position sensor on 2009 saturn aura
2.4L cmp sensor exhaust located upper rear of the engine near camshaft cover. 2.4L cmp sensor intake located upper front of the engine near the camshaft cover. the 3.5L cmp sensor located right side of engine compartment above the timing chain cover.below power steering pump.3.6L cmp sensor located right side of the engine near the front and rear.
Sep 26, 2013 | Cars & Trucks
Nissan terrano 1996 2.7 diesel
The sensor is located behind the crank pulley/harmonic dampener. To replace:
1 Remove the tire/wheel and splash shield.
2 Remove the bolts, then loosen the mount bolt and pivot the side engine mount out of the way.
3 Loosen the idler pulley center nut and adjusting bolt, then remove the A/C compressor belt.
4 Loosen the alternator mounting bolt, nut and adjusting bolt, then remove the alternator belt.
5 Loosen the mounting nuts and adjusting nut, then remove the P/S pump belt.
6 Remove the dipstick and pipe.
7 Remove the crankshaft pulley.
8 Remove the upper covers and lower cover. NOTE: Do not use the upper and lower covers for storing removed items.
9 Remove the CKP sensor from the cylinder block.
10 Install the CKP sensor in reverse order of removal.
Feb 23, 2013 | Cars & Trucks
I cant locate the knock sensor where do i find it?
There are 2 knock sensors located below the upper intake manifold. With the intake removed follow wires to the middle of engine near the front and back. The sensors are recessed in the lower valley pan and covered by some type of insulating material. The rear sensor usually fails due to water working past the insulating material and filling the hole with water and covering the sensor, causing it to rust. Remember to replace the upper intake gaskets and injector o-rings. You dont want any other driveabiliy issues after this repair.
Mar 25, 2012 | 2001 Chevrolet Suburban
Cheak cover why
When you open cover, from left inner side of cover is plastic nose, that fits into sensor hole. With screwdriver, remove 4 screws, remove fax cover, and put sensor in upper position.
Jun 07, 2010 | Canon LaserClass 2050 Plain Paper Fax
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
B4600 pane screen says I have an exit jam and to open upper cover and remove. THERE IS NO JAM!!
Open that cover look for the sensor it could be a dirty sensor or the spring came loose that flips the sensor back into position.
Oct 30, 2009 | OKI B4600 Laser Printer
How to empty waste toner container on 2404wd
3. Right upper cover (" x 2)
4. Right cover (" x 3)
6. Toner overflow sensor (# x 1, " x 1)
Oct 23, 2009 | Office Equipment & Supplies
OKI B4350 Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
