Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint Aquarius Machines Water Tank Bottle hitting back
My Aquarius washer/dryer is having a unusual problem.
On the back is a slam panel of sorts, a sheet metal backing, this it appears from the contact marks is making contact with a plastic water bottle placed to collect the soap/conditioner from the intaker on the front of the machine.
We have removed the sheet metal backing and are in two minds if it is safe to run the machine without this backing as the back of the machine would be exposed to show the belt etc, however it would stop the problem, and the machine is covered top, bottom, left and right by kitchen panels.
Any tips are appreciated as we really need the machine working and with us moving soon ££'s are tight.
  • 91 Answers
You can leave the back off but make sure that no one can be harmed by the moving parts , it will be louder but i would do this :where the bottle mark is , use a heavy 2 1/2 lbs + hammer place the pannel on a sand bag and stretch around area plus extra iches .as this way is at no cost
Posted on Aug 31, 2009
Hello, I bought an Hotpoint washing/dryer Wdl 540 acquarius+ last year and since then all my house stink of ****. Especcially when the dryer is on and all my clothes and my house stink terribly. What can...
Because the units are combined the dryer has a built in a condenser dryer which should have a water retaining tank and if not emptied regular it can stink like ****. You need to empty the tank. Your model should pump the moisure out but has a reserve tank.
Jul 26, 2011 | Hotpoint Aquarius WD640 Front Load...
The washer is coming on but wont spin
if you mean the drum wont turn after filling with water...... then the motor may need new brushes............ costs about £12 max n tack you about 10 to 15 mins to sort.........
cheers
Mar 24, 2011 | Hotpoint Aquarius WD63 Front Load...
The water heater on my hotpoint aquarius wd440 1400 spin washer drier came out causing water to flood out my kitchen i have knocked it back in but it came back out again should there be some sort of a clip...
I trust this is the water heater you are referring to...There is a large nut 10mm in the centre of it this has to be tight,this in turn will Expand the rubber water seal and in effect stop any leaks...God luck
Feb 11, 2011 | Hotpoint Aquarius WD63 Front Load...
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1000 washer/dryer
cleared blockage from end of drain from machine.
Jul 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD440 Washer/Dryer
remove bottom rear panel. you will see a large diameter hose going from tub to pump. undo this hose at the tub end - lots of water will come out. filter is inside this hose. remove and clean
Jul 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint washer dryer
daidan, If you unplug the washer and it still fills you have a bad inlet water valve. If you post the complete model number we would be able to help you better...Catriver...post back
Aug 21, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
