Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Why is chevy s10 4.3 engine misfiring on one cylinder
    Problem Solver:
  • 19 Answers
Check the plug wire/boot and replace it as a starting point. Put in garage or check at night for arc ... look at it for cracking and other deformations. If you have not done a full replacement in a while that is a good start. Another point of contact is on the distributor cap side. Yes the world is not aimed at a distributor but the cap itself can develop cracks or wear. Start simple.
Posted on Jul 21, 2013
97 chevy 1500 sputters at idle in gear can feel it a little while driving no cat. past 2 years run bank1 lean code plugs clean HELP
If the engine is misfiring the check engine light would be on and blinking and the engine control module (PCM) would store a fault code or codes for the cylinders that are misfiring. A lean code will not cause a misfire unless the engine has a vacuum leak most often at the intake manifold gaskets. A misfire code looks like this:
P0300-P0306 for 6 cylinder and P0300-P0308 for a V8.
P0300 indicated a random engine misfire, this can be caused by all kinds of issues.
Feb 24, 2017 | Cars & Trucks
Have a misfire in cylinder 6 changed all coil packs all spark plugs stills says cylinder 6 misfire
A misfire could be caused by almost anything, spark--fuel--compression. Did you check for spark at number 6? All electrical components have voltage and ground, if problem on wiring circuit, replacing the component won't fix it.
Also, check for fuel injector pulse--proper fuel pressure and cylinder compression.
I don't know year--make--model, it didn't post for some reason?
May 16, 2016 | Cars & Trucks
Check engine p0301
It is a misfire code. It mean that there is a misfire on that respective cylinder in the firing order. For example, P0306 means "misfire cylinder 6", P0302 means "misfire cylinder 2" and so on.
If your car has one of these codes you need to get it fixed asap. If you choose to drive your car in this condition you will do damage to the catalytic converter.
Jan 12, 2016 | 2005 Chevy Colorado - 3.5L 5-cyl. engine -...
Cylinder 6 is misfiring. What was will fix this problem? It's a 5.7L v8 in a Chevy 1500.
You don't say what year the truck is, so I will guess on the fuel system.
You need spark, fuel, and compression for the cylinder to produce power. One of the three is missing.
If the engine has multi-port fuel injection the injector for that cylinder could have failed.
Could also be a plug, plug wire, or something mechanical.
Aug 12, 2013 | Cars & Trucks
Chevy vortec 305 misfire on # 6 cylinder
Could be 1 of 3 things sparkplug fouled,sparkplug wire or a faulty injector or injector wire connector has a poor connection.Also if this engine has 1 coil per cylinder then the coil for that cylinder could be faulty.
Jan 20, 2012 | Cars & Trucks
What can cause a cylinder 1 misfire in a 2003 Chevy impala with a 3.4 liter engine
Misfire reasons.
Bad ignition coil (there are 3 of them), bad spark plug, bad spark plug wire (most common) defective fuel injector, intake manifold vacuum leak, low cylinder pressure due to burnt valves or scored cylinder walls.
Sep 25, 2011 | 2003 Chevrolet Impala
My 2005 Chevy Equinox LT has a number 1 cylinder misfire. I already had the spark plugs and wires changed. I also had the coil changed and it still misfires. I checked it with my OB2 computer, and it reads...
Have you done a compression check? I had the same problem on an S-10 Chevy pick up. Found that # 3 cylinder had low compression due to a burnt exhaust valve. No more problems after having valve job done on the engine.
Feb 16, 2011 | 2005 Chevrolet Equinox
Engine code: Misfire cylinder 1. Replaced plugs
There should be no built up fuel or oil in cylinder. The fuel will be burned off immediately, and there should have been very little unless you have a leaking injector. The only way oil will enter the cylinder is if you have a mechanical failure like worn rings or leaking valve seals.If after replacing the plugs and wires did not correct all or the skip after the first start up and road test then you have another issue causing the skip
May 23, 2010 | 2004 Chevrolet Malibu
I have a 2000 chevy blazer 4.3l engine\is backfiring
Start by checking each cylinder for spark with a good spark tester. A misifre is either spark or fuel, so you can cut the problem in half. The engine light is probably on due to the misfire.
Sep 20, 2009 | 2000 Chevrolet Blazer
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
65 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
Robert McCall
Robert McCall
 Russ Hill
Russ Hill
Joel C.
Joel C.
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
