Question about RCA Audio Players & Recorders
I have XM radio hooked to cassette player adapter in my car. The new adapter keeps sounding like it is rewinding. XM plays for 30 seconds and then ''rewinds'' again, over and over.
  • 89 Answers
Unfortunately your tape play has the auto reverse feature. It is detecting that the tape is not turning via a reel counter. Sensing no movement ( as you have an audio adaptor inserted rather than a real tape) it is trying to switch to the other side of the tape.
Not very much you can do.
You could purchase an FM modulator and basically re-transmit the Xm over an un-used frequency on the FM band to slve your problem
Posted on Mar 12, 2009
HOW DO I FIX THIS MY CASSETTE PLAYER OUT OF NO WHERE STARTED MAKING A CLICKING NOISE AND WILL EJECT THE ADAPTER OUT .
First, nobody has used the Cassette Adapters since Milli Vanilli got caught Lip-Synching and Mike Tyson got knocked out by Buster Douglas. U can buy a new radio on ebay for under $30 that has what is now called an "Auxiliary" cord or "Aux" cord.
http://m.ebay.com/itm/Car-Audio-Stereo-In-Dash-MP3-Player-Radio-W-USB-SD-Input-WMA-AUX-FM-Receiver-/141663164502?nav=SEARCH
Second, if u are set on keeping that stone-age paper weight u call a radio (I had one of these too, up 'till 2 yrs ago), try to play an actual cassette tape. See if it gives u the same results that the adapter gave u. If it does then the problem is in the radio and it might cost more to fix than it's worth. If it doesn't give u the same results, then try to find what is referred to as a "cassette deck cleaner kit." After u follow the directions on the kit try the adapter again. If the issue continues, then try a new adapter. By this point u are probably going to be 1/2 way to the $30 it cost for a new radio. Short of that, there isn't much else u can do unless u want to open up the radio but again, not worth the trouble.
Good luck.
Aug 13, 2015 | 2005 Honda Accord
1999 Honda Accord Cassette Player Problem
Cleaning the Radio may fix it but what it sounds like is there is a lever inside that got jammed and you have to take the player apart to get it to work again.. Cheaper to get a new one
Apr 09, 2013 | 1998 Honda Accord
My car doesn't have a cassette player, an audio jack, or an exterior antenna for xm sure connect, is there anything else i can get for it to play?
You need a FM direct adapter its plugs in behind the radio in your antenna. the part number is FMDA25its says Siruis but it works for XM.
Feb 16, 2011 | XM Radio (XMP6000)
Cassette player doesnt play or record, ff or rewind. CD player, AM/FM radio works fine.
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Jan 14, 2011 | Memorex MP3227 Radio/Cassette/CD Boombox
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
I have a bose stereo in my 96 nissan Maxima that works poorly
there is a problem in the tape drive - possibly a bad belt- thats why the cassette adapter keeps ejecting itself- most add on xm tuners have the ability to broadcast its signal wirelessly-you press the menu button then turn the tuner to select the menu option that you want then press on the tuner control again to choose broadcast (fm signal and which channel you want to broadcast to the factory radio-try www.xmradio.com for more detailed info
Apr 16, 2008 | Car Audio & Video
Cassette player connection
hi there, you just have to make sure that you're cassette deck is clean..then try it...if it won't work, you have to buy a new cassette adapter..i can assure u it'll definitely work..
Dec 03, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
191 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
