Question about Packard Bell Speaker Computer Speakers
Need to no the dc volts to run fps 9634 speakers
10V 1.2A. -ve polarity on outer connector
Posted on May 02, 2009
I have Cintre desktop speakers but no power supply. Where can I get one?
first off need to know specs what voltage it uses ac or dc
amp draw and volts should be market on speakers then you need to no if dc volts what part is negative and positive on terminal connection send model #
Feb 27, 2015 | Audio Players & Recorders
My dc691p speakers require 9 vold dc. Will it do any harm to use a 19 volt dc
yes, your speakers will be damaged. do not connect 19 volts to a 9 volt device. go to walmart or radioshack and purchase the correct power supply.
Mar 01, 2014 | Juster AC-691 Computer Speakers
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
May 30, 2011 | Koss HD 50 Computer Speakers
What voltage are the koss 'older' computer/CD speakers that would take 3 'C' batteries each. I have a variable voltage adapter and am not sure if I should switch it to 9 volt or another setting for AC...
C cells are 1.5 volts each. If the speakers use three of them that means you'll need a 4.5 volt supply. If each speaker needs batteries, you'll need to feed that voltage to each speaker, and the supply should have enough current for the total load. A 1-amp rating is probably fine.
Dec 24, 2010 | Koss HD 50 Computer Speakers
What voltage and polarity do the ACS-5 speakers require?
Computers always use DC voltage. Computer speakers receive DC voltage from the computer.
DC voltage has a Positive and Negative polarity.
In the power jack of the speaker, the Center pin is the Positive connection. The outer shell is the Negative connection.
Center hole of the DC adapter plug - Positive.
Outer shell of the DC adapter plug - Negative
Voltage 5 Volts DC.
In case you need it,
http://support.dell.com/support/edocs/dta/acs5/
Nov 29, 2010 | Computers & Internet
Need to know the voltage on the dc power adapter for ACS5 model
Hard to find info. It looks like they run on about 14 to 15 volts dc. It's not critical. Check local electronic surplus stores or thrift stores before spending a lot more elsewhere.
Oct 06, 2010 | Altec Lansing Multimedia Computer Speakers
I need a driver for a Maxell FPS-2 Flat Speaker System
You do not need a driver for these speakers, all you have to do is plug them into the sound card on your computer. If the speaker audio cable is colored green, then you should just be able to connect it to the green plug on the back of your computer. If not, what does the audio plug/jack look like?
Jul 28, 2010 | Maxell FPS-2 Computer Speakers
What is the dc input for JBL Media 100
They run @ 12 volts 850mA. So an adapter with center pin positive at around 1A(1000mA) would give it enough "headroom". This means it would run cooler and last you longer. Amperage consumption is determined by the power it is producing, how loud you are playing the setup.
Mar 13, 2009 | JBL Media 100 Computer Speakers
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
Voltage adapter
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Sep 24, 2008 | Altec Lansing AVS 300 Computer Speakers
Packard Bell Speaker Computer Speakers Logo
348 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
David
David
Henry  Thomas
Henry Thomas
SHIVAJI YADAV
SHIVAJI YADAV
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
