Question about Water Heaters
Water heater not working?
I have a Intertherm electric water heater. Model Number: HSE-52F-240D, 50 Gallons. We have well water and our pump wasn't working properly for a few days, as soon as we noticed we shut the water heater off. We were able to fix the pump yesterday and turned the water heater back on after it had filled up completely. We ran water through the lines but waiting until this morning to expect warm/hot water, but unfortunately, something isn't working properly, because we don't have any. I've flipped the breaker and have tried resetting the water heater itself, but it doesn't seem that the reset button fully engages as it should. This water heater has two thermostats. I'm new to all of this, but am trying to save money, and really hoping the whole thing doesn't need replaced. Any information would be greatly appreciated!
  • Water Heaters Master
  • 15,937 Answers
There is a suprising lack of information on those water heaters. Do you have any idea how old it is? Is it in a mobile home?
Posted on May 05, 2013
SOURCE: Thermostat and reset button (GIANT 152ETE) - no hot water
I have the smae problem but my element on top works fine it is the element on the bottem that does not go on so what is it that i have to change the element or the thermostat. on the bottom or the one on top. I have voltage on the top but none on the bottom element and are they suppose to go on the same time.
Posted on Apr 16, 2010
  • 68 Answers
SOURCE: residential electric hot water heater throwing br
If you reset the water heater the first time you were without, Then odds are it is the water heater. probably an element went back. If the power off check for continuity.
Please rate this response and Good Luck, Phil
Posted on Dec 28, 2008
SOURCE: Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Posted on Oct 11, 2009
heatman101
  • 43501 Answers
SOURCE: water heater needs a jump-start every morning
Did they change the thermocaouple or the gas valve/thermostat???
My gues is that they changed the thermocouple and NOT the gas valve which also has the thermostat in it.
The gas valve is the problem... make them change that or give you a new hot water heater.
Heatman101
Posted on Mar 22, 2010
  • 760 Answers
SOURCE: i have a 50 gallon
If you're having to reset the breaker, then most likely you have a bad heating element. Usually the bottom element burns out first, however if you had the water off, and the level dropped in the tank, the heater might have come on without water in it. This will cause it to overheat and burn out. Now when you turn the breaker on, the current is going to ground, tripping the breaker. If you are handy you can replace them, but be sure water heater electric is off or disconnected, and then drain water below the element level. While you're replacing one element replace them both.
Posted on Oct 13, 2010
Does an Intertherm water heater model HSE 30F 240S have a dip tube? Cold water comes n on the side of the tank not on top or bottom.
How to Repair or Replace Defective Water Heater Dip Tubes
www.familyhandyman.com > Skills > Plumbing
The role of the dip tube is to direct incoming cold replacement water to the bottom of the tank for heating. While it warms, the dense, cold water stays naturally segregated from the warmer, lighter water floating on top. The water for faucets and appliances comes from the hot layer on top.
Jul 28, 2015 | Water Water Heaters
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
Had to replace main board and power supply, now have a heat pump error. HPF code F4.Unit is 2 years old.
Type, brand, model number of water heater is not known.
If you have GE heat pump water heater, the parts are covered after first year for defects in workmanship. Otherwise the expensive water heater is not covered if it stops working.
The risk of failure is perfect reason to avoid expensive water heaters, because all costs are energy, and these units cannot guarantee longevity, even with correct and regular maintenance.
If your new laptop computer needs a motherboard, that's red flag that the computer machine will never work correctly again. Same is true for water heaters, or any expensive digitally-controlled appliance.
Same is true for tankless water heaters and hybrid water heaters and condensing water heaters and complicated solar water heater systems.
Call the manufacturer and see what they say.
Check voltage to unit. Make sure the unit is grounded.
Post question with exact mode and brand name on professional water heater forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 13, 2012 | General Electric Ge Appliances GEH50DNSRSA...
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I am trying to drain my electric water heater: Servistar, model no.06443 serial no.0496B02329, watt: 1-PH,Upper 4500 240 volts only, Lower 4500 Cap. U.S. Gallons 50 Total 4500 I closed the cold water...
Hi Karen, think of the water heater as a straw....if the straw has liquid in it and you put your finger on the top, the liquid doesn't come out. If you open up the relief valve, air will allow it to flow freely. The relief valve has a metal lever on it, usually on the top of the water heater (if electric).
Feb 06, 2010 | RTO Home Heating Products 5.5HH240...
We have a 83 Gal. Rheem 41V50 40,000 Btu - What do we replace it with? It is leaking
The model number you gave is for a 50 gallon tank, not 83 gallon.
50 gallon ones are readily available, including the same model..
Oct 20, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heaters Logo
122 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
