Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FK1CW
Frigidaire freezer Model No. FFU14FK1CWO leaks water on floor
Our freezer is a frost free model, apparently without a defrost drain. Periodically, ice will accumulate in the bottom of the freezer and water will overflow out of the front when the freezer goes into automatic defrost.
  • 2 more comments
  • pro29 Mar 12, 2009
    I see no evaporation pan under the freezer. Does the water just drain out on the floor anyway?
    I see no evaporation pan beneath the freezer. Does the water just drain out on the floor anyway?
    I have removed all ice from the bottom of the freezer and there is NO DRAIN! in the bottom of the freezer compartment.
    I have a parts catalog. It does show a drain tube at bottom, front left. If it is there, it is inside the refrigerator walls.
  • 15,935 Answers
There should be a drip pan installed.
your defost moisture will continue to drip onto the floor without the drip pan installed.
it rarely has to be emptied because it will evaporate in a few days.
an abundance of water is indicative of an improper seal, defrost timer, or faulty thermostat.
Thanks for using FixYa!!
Posted on Mar 12, 2009
    Sergeant:
    Novelist:
  • 277 Answers
For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
  • 6,784 Answers
Hi, if you have a humidity control switch, i would set it at a lower setting. also, check the level of the fridge to make sure its not leaning forward. even the slightest lean one way or the other will direct the water flow away from the proper draining hose. An unbalanced fridge will also not allow the door seal to properly do its job as well. this will increase the frost build up. I think your fridge may be slightly of the level mark at this moment, pushing the water to the front.
  • 170 Answers
Here is a link to the Manufactors product information sheet, it covers both with and without the drain plug.
Hope this helps...
ftp://ftp.electrolux-na.com/ProdInfo_PDF/StCloud/297245700en.pdf
If so please rate my solution accordingly.
Thanks,
David
  • 2,984 Answers
Do me a favor....call the professionals....
Here's the number!
U.S.A.
1 (800) 374-4432
Monday - Friday
9:00 am - 5:30 pm EST
  • Greg Bernett
    Greg Bernett Mar 12, 2009
    Call the professionals...here is their number and they WILL help you!
    U.S.A.
    1 (800) 374-4432
    Monday - Friday
  • Frigidaire Master
  • 19,396 Answers
The drain hose is part 29 on the diagram below:
Try also setting thermostat to lower settings, if the fridge continues icing up on all condition you may have a slightly defective thermostat.
Check also that the door gasket is sealing well the door when the door is closed.
    Brigadier General:
  • 3,614 Answers
See the drain outlet and the drain pan at the lower back of the machine
  • micromaster
    micromaster Mar 12, 2009
    The
    drain ports are located along the bottom of both the freezer and the
    refrigerator sections of the unit. These holes can become clogged with
    debris or ice, causing a drainage problem when the unit is defrosting.
    To clear the ports, use a short section of wire that will fit the
    holes. Do not use a toothpick, because the wood may break off in the
    port and become stuck. On some refrigerators, the drain ports are
    located near the defrost heater at the evaporator coils. A lot of
    disassembly is required to clean this type of unit. If the refrigerator
    or freezer is this type, you may be better off calling a professional
    service person to clear the ports.
    On some freezer compartments,
    the drain is located under the freezer compartment and shaped like a
    shoehorn. This type of drain can usually be unscrewed so that the drain
    area can be cleaned.
  • micromaster
    check the
    drain hose for cracked, causing leaks. Examine the hose. If it's damaged, replace it
    with a new one of the same type. If you spot water on the floor, the
    drain pan may be tipped on its brackets, or the pan may be cracked or
    rusted. To eliminate the leak, realign or replace the pan.
    Sergeant:
  • 254 Answers
Most/many times this is a clogged up or restricted defrost drain system, but once in a while the drain system has been cleaned and everything appears to be good but you still get ice in the defrost drip tray and such and the drain freezes over.
as repair kits are available in the market for this problem
http://www.applianceaid.com/defrost_drain_freezes.html
click the link and get the repair kit.
  • 412 Answers
There should be some clog on the pipe.
  • remoteserver Mar 12, 2009
    chane out the drain pipe, and see if it works......
    President:
  • 1,314 Answers
All have drains something is blocking yours or its frozen should be a white plastic if you look in the slot center at the bottom of the back panel take hot water and pour there till you see a white disc with holes in it clear that
    Top Expert:
  • Frigidaire Master
  • 78,289 Answers
Replace the defrost realy and maybe the timer as well, it is one of those 2, the relay is the most common and cheap to buy.
  • yadayada
    yadayada Mar 12, 2009
    that is defrost relay, not realy
    Guru:
  • 462 Answers
All self self defrosting models have a drain (even modern manual defrosting of larger size have drains). I suspect yours may have ice covering the drain and maybe something else. I have seen price tags (back when they were used) small tags and some plastic that came off frozen food plug the drains. And even gunk from the refrigerator side can find its way into the drain maybe even egg shells. Take some warm water and pour in the drain pan (in the freezer compartment usually under the back panel on bottom) and let it set over night with the freezer off and the door open or start this one morning early and within 6 hours if you leave the door open and have a fan to force room air into the freezer most of the time the ice will thaw and your drain will be open. Now after you have lost this initial deposit of water pour some more and see if it goes down the drain. you may be able to hear it come out into a pan underneath. If it comes out the sides or front the drain line is loose or torn apart and you will have to remove the pan to see what needs fixing then.
Hope this is clear and helps please rate me accordingly and Good luck
  • Farley Redfield
    Farley Redfield Mar 12, 2009
  • Farley Redfield
    Your freezer is that JUST a freezer? and the shelves do not get frost on them and require defrosting? Then it has to have a drain hole and its stopped up. Take some water and pour in the drain pan see if it goes down it could be frozen over or a paper tag or something stopping ti up. Or it could be stopped up from the outside. If the water disappears the drain is open if there is Ice at the bottom back (might be raised up some off the back floor not in the floor necessarily)
My upright frost free freezer is leaking water onto the floor.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I can only be general. Your model number is on a label on the upper side wall.
You have one of three problems.
1.) A bad defrost timer.
2.) A bad defrost Heater.
3.) A frozen drain.
4.) A obstruction/leak - Large block of ice in the upper right hand corner of your cool coil.
Mar 12, 2015 | Frigidaire Freezers
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
No drain plug in freezer to drain water out when defrosting?
The drain hole is behind the back wall underneath the evaporator coil. Im guessing you have ice on the freezer floor. This is because the drain tubing from the freezer to the drain pan underneath is clogged. There will likely be ice that will need to be defrosted in the drain tubing in order to get to the clog. Once the ice is removed, I use compressed air when I perform this refrigerator repair service.
Sep 27, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Apr 05, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Nov 19, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Kenmore upright freezer-model LFFH2067DW2 -the red light has been on for at least 12 hours and the freezer is defrosting-water is leaking on the floor-there is a vent insidethe freezer and the...
I was made aware of your concern and would like to offer a few ideas you may want to consider. Water dripping down is not a leak during defrost condition as this would be the ice melting. Normally, there would be a drain hose specifically to channel the melted ice/water to a drainage system. The amount of water would then be proportional to the amount of ice melting as with the length of time to completely melt, drain away.
Perhaps you could check the filter/drain screen as well as the drain opening for any blockage/clogging. You could also try checking the same on the drain hose as well as for possible kinks. Additionally, there would be a sensor behind a boxy cover that triggers the system back into operation. If there is still melted ice/water inside the freezer, then the sensor would prevent the unit from turning on completely. You may want to check this sensor and verify that it is dry.
An exploded parts diagram would help you identify/locate the above mentioned parts.
Good luck and thank you for using FixYa.
Feb 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer FFU14FK1CW Logo
2,931 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
