Line of pixels flicker between Greeny/yellow white and black the problem is spar attic and sometimes works fine especially when first turned on
    Top Expert:
  • Televison & ... Master
  • 75,471 Answers
Posted on Apr 22, 2013
4 Suggested Answers
chain saw
  • 94 Answers
SOURCE: Red pixel cloud in plasma black
THIS IS THE START OF THE PLASMA GAS RUNNING OUT...PLASMA TVS ONLY LAST 4 TO 5 YEARS THE GAS JUST BURNS OUT....LCD TVS LAST ALOT LONGER UP TO 10 YEARS..
Posted on Feb 23, 2009
zjut
  • 106 Answers
SOURCE: Bright Red 1 pixel line on left quarter of screen
It could be the logic scan board failure (you can open the back cover to locate the exact board and you can replace it if you can find a spare board), or the panel failure (it's the beyond economical repair case).
Posted on Jan 20, 2008
SOURCE: white horizontal flicker on screen
Sounds like the logic boards on its way out
Posted on Feb 02, 2008
My LCDTV has a problem, Model number is 6626LCT, Now on to the problem, While doing yearly cleaning on my tv as normal, after i plugged it in it was normal for 40 seconds, It flickered and the screen went...
Only suggestion is if set was plugged in when you did what you did--unplug it and any box or receiver plugged in and wait a while--plug back and let the equipment try to reboot.
Jun 06, 2012 | Sylvania Televison & Video
Yellow screen hp dv6000
The screen is faulty or the screen cable has become dislodged. Best take it to a repair shop.
Oct 12, 2017 | HP Computers & Internet
I am trying to replace an old spring loaded attic fan timer. The old time simply had a black line in and a black line out. There was both a white and red line capped off in the box along with a bare...
The timer is wired differently than the old spring-loaded timer.
This is because the timer has an electronic clock instead of a spring.
The electronic clock needs power just like an alarm clock.
The white wire powers the clock.
Here's the wiring.
Black-timer wire connects to Hot-wire-from-breaker
Red-timer connects to Load (attic fan)
White-timer connects to white Neutral
In absence of a Neutral, connect white-timer to bare ground.
If you have your black-timer and red-timer wires reversed, it might cause the symptoms you describe.
Simply reverse the black-timer and red-timer.
If you want to test your wires to make certain:
Remove timer.
Separate wires for testing.
Turn on power.
Use ordinary tester.
Tape tester leads to wood sticks to keep hands away.
Power is ON.
Test each wire to bare ground wire.
When tester lights up, that is hot-wire-from-breaker.
Now test hot-wire to each of the other wires (except ground)
When tester lights up, that is Neutral
Not every switch box will has a Neutral
In that case white-timer connects to ground
Nov 08, 2010 | GE 60minute Automatic ShutOff Timer Switch...
Screen went greeny/yellow colour shut down i'm getting no image
no way bro if you have any type of hardware failure microsoft fixs it for free! your warrent was with a store not sony.. all they would do is tryed you it for a new one! microsoft will fix it for free dont worry!
Aug 04, 2009 | Microsoft Xbox 360 Console
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
Jul 09, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Only view in black and white on my ilo DVD R04
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
May 11, 2009 | iLO DVDR04
Dell Inspiron E1505 shows green pixels instead of black
the color pixels are different sections in the screen and the green section might be cracked
Apr 24, 2009 | Dell Inspiron E1505 Notebook
Phone screen goes blank to a grey color (externallY) .
same problem, broke my screen, ordered a new screen off ebay and replaced it. now it works fine most of the time but sometimes external display freezes. sometimes goes black, sometimes goes multicolor pixelated (full screen, in blocks, or lines) when this happens sometimes touchpad still works, others not. removing battery usualy temporarily fixes.
Mar 09, 2009 | LG VOYAGER VX10000 Cellular Phone
My tv picture is dark and flickers
is there any spar, u observed inside the tv when it do like this.
Jul 05, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Jan 03, 2008 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
