Question about Kitchen Appliances - Others
Whirlpool Ice Maker is not freezing the water to make ice. The water is being pumped to the freezing tray, but no ice forms.
  • rparris31 Mar 12, 2009
    thank for your input but this unit is a stand alone ice maker. I have cleaned the condenser, the fan is running and like I said the water is running but not freezing. Yes the temperature has been in the 70's and 80's but the air conditionng is also on in the house. The only conclusion I can come to is the compressor has failed. I have replaced the pump and a solenoid valve in the last several years. I hate to replace the whole unit at a cost of about $1500. Any suggestions?
  • 462 Answers
I assume your in an area where the temperature has been in the 70's? or more lately? In fact if your not freezing water in to Ice you have a freezer problem that's going to get worse before it gets better. I suspect that you have either a Air movement, defrost problem, Or a dirty condenser.
The quick check for air movement: main thing is make sure the controls are set in mid range, any extreme end of the controls may keep too much air from the refrigerator going into the freezer making it too warm.
Defrost elimination (Check the floor or back wall on a top or bottom freezer fridge or the back wall of a Side X Side look with a mirror if possible) A problem here will require more information as to how to proceed. What make is it do you have a volt ohm meeter...
Of these this one is more likely especially if you've had some warmer weather lately. Look under the frig and behind it under the panel that covers the compressor area. See anything that looks like dirt and lint covering a large portion of the coils under the box??? vacuum or blow it out with compressed air and replace the panel give it 24 hours and see if you have ice.
Posted on Mar 12, 2009
  • Farley Redfield
    Farley Redfield Mar 13, 2009
    If its been on a while you need to let it sit off for 10 to 20 minutes before plugging it back in. If its been off you can proceed.
    Take the back off (or front) so you can see the compressor. Stick a towel or other cloth on the fan blade beside the compressor to keep noise and vibration down.Turn it on to freeze and feel the compressor. If the compressor turns on and you feel the vibration from it running it at least runs.
    If you hear a slight hum and then a click your compressor is not running but it may be the start components bad not the compressor its self. Only way to know is try new components or a self contained relay overload and capacitor. (RCO410 or RCO810 Are 2 of the all in one components available at a supply house you probably need the 810.) With new components properly installed on the compressor, you can now be certain its either the compressor or the components you just replaced.
    If you turn it on to freeze and you get nothing (the fan motor under neath should not turn on either) you most likely have a bad freeze thermostat. Begin by checking voltage to the compressor and verify you have that if not then the freeze stat is the place to start. If you have voltage and the compressor doesn't hum or try to start, let it cool off til room temp and try again. Still no start your compressor is shot.
    If this helps you please rate me accordingly.
Ice maker leaking water and freezing in the freezer (ice-cycle forming)
The solenoid controlling the amount of water entering the tray is not shutting off properly and overfilling it.
Jun 25, 2015 | Whirlpool 22 cu. ft. Side-by-Side...
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Whirlpool ED5VHEXVQ03 side by side. Ice maker is not making ice. Checked water line - okay. Checked water valve - okay. Water filling tray - okay.
Whirlpool Ice Makers are about the hardest working part on your refrigerator and their average life is about five years. You can fill the tray with tap water if the ice slots are already empty and let the water freeze. If after the water freezes and the ice drops to ice bin then the water control valve.
Click Here=> 4389177 Water Inlet Valve will need replaced. You mentioned the water is filling the tray OK then my focus would be on the ice maker.
Click Here=> W10190965 Ice Maker Assembly
Most times it is less expensive to just replace the ice maker module. Here is a helpful video that helps explain everything about the Whirlpool Ice Maker below. If you find this solution helpful please rate my solution, Thanks Sea Breeze
Jun 29, 2011 | Whirlpool Refrigerators
I have a whirlpool gold side by side model number g56nhaxu500 it is 2 years old and weve never had a problem til now. our ice maker tray keeps freezing and we cant get it out. ice forms underneath it and...
The water solenoid that supplies water to the ice maker is faulty and the solenoid needs to be replaced. What it is doing is filling to a certin point at regular speed and then not sutting off compleatly and dribbling until it starts flowing over the side. Please rate my assistance. Thank you
Sep 05, 2010 | Whirlpool Refrigerators
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ice maker makes impure ice but the water is crystal clear and good. replaced filter and cleaned ice maker tray ect.... no change. Is there a way to sanitize the water line to the ice maker?
what you are seeing in the ice is the impurities in you water. you wont see them until the water freezes because you are trying to freeze the "H2O" and not the calcium and magnesium. those are what causes your ice to look cloudy.
filtering the water does help but you cant get perfectly clear ice with this type of an ice maker.
when you see "store bought" ice and it is clear, that is because it is made a different way to prevent the impurities from forming in the ice.
also the longer the ice is in your freezer, the more it will absorb from the air causing even more cloudiness.
Jan 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker not freezing the water. teeth still appear to be turning but water only freezing due to cold freezer. water mostly overflowing and forming icicles all over the freezer section. have removed ice...
the freezer is supposed to freeze the water, the icemaker is just the form for the ice and the motor is to free the ice from the form, make sure water supply is cold water and not hot
Oct 10, 2009 | Whirlpool Refrigerators
Sub-Zero 550 - freezer unit is chilling, but not freezing
Ice maker was intermittent at best - ice was often just a shell. After two failures to correct we had the ice maker (a Whirlpool - on a Sub Zero - Go figure) replaced. Then the paddle that detects the ice level broke. Next step a new GE.
Jun 13, 2008 | Sub-Zero Bottom Freezer Refrigerator
Sub-Zero Under Counter Ice Maker not making Ice
ice stat defective
hot gas solenoid vavle defective
pls post make /model.
if ignis / whirlpool then above points should the trick.
lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
Feb 20, 2008 | Freezers
Kitchen Appliances - Others Logo
700 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
