My autocad 2007 file is not open properly. when i opened it auto cad will be hanged and didn't respond anything my file size is 50mb over
    Champion:
  • 401 Answers
Open .dwg file by using of corrupt .dwg recovery utility
Article http://www.oemailrecovery.com/dwg_recovery.html helps you in this matter
Posted on May 16, 2013
SOURCE: autodesk autocad 2006 activation cade
i have lost activation code for autocad 2006
Posted on May 02, 2009
  • 323 Answers
SOURCE: opening dwgs in autocad
In the past the fastest way to fix this is to go directly to the file and try to open it. It is possible that file or database has been corrupted. In some instances the file type dwg is not associated with autocad and the application hangs because it is looking for .dwg as an associated file type to autocad.
Let me know if you need further clarification.
Posted on Jun 11, 2009
  • 13 Answers
SOURCE: Autocad hanged
1. Please check your computer specifications. Normally 2010 Autocad, require a good ram and video card.
2. It also hangs when opening a lower version of cad file.
Posted on Mar 29, 2010
f700es
  • 49 Answers
SOURCE: Autocad 2009 hang when i
Open up Windows Task Manager and look under the Processes tab and see if WSCommCntr2.exe is running. If so stop this process and see if this makes a difference.
Posted on Mar 03, 2011
  • 115 Answers
SOURCE: NET is not installed, AutoCad
Go to Window's update center and make sure .NET is fully up to date. If you cannot find it there go to mircosoft.com and search for .NET, then follow their instructions to install it.
Posted on May 14, 2011
Testimonial: "Perfect suggession thank you"
How to recover AutoCAD files from flesh card?
If you need to recover it as fast as it possible install Recovery Toolbox for DWG , this thing is able to help you. But it's not free. Download free demo here:
http://www.dwg.recoverytoolbox.com/
As one of solutions I can advise you to try to open your files in MS Visio, Compass or using another program which could open dwg file. Or try to recover them using AutoCAD recovery function.
Also you can read here about dwg file corruption:
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/561-how-to-recover-autocad-files-from-flesh-card
Nov 27, 2014 | AcroCAD Software AutoCAD DWG to PDF...
My AutoCAD 2007 is not working properly. AutCAD message is displayed on the screen making it unable to open my file. What shall I do to eleminate the autocad message.
my autocad 2007 file is not open properly. when i opened it auto cad will be hanged and didn't respond anything my file size is 50mb over
Nov 12, 2012 | Computers & Internet
I cannot open Auto Cad 2006 due to the above message it opens so far then this comes up and it goes out of Auto Cad immediately any suggestions or solutions
hi
try to update your system once
or download a new copy of autocad 2006 from torrentz.com for free
vote me if it helps you
Apr 11, 2011 | Computers & Internet
Autocad hanged
Jan 12, 2010 | Autodesk AutoCAD 2010
I recently openned a file from a friend and since then my autocad has got me crazy i have to run everythig under commands, ie: if i select something ang press the delete key it doesn't works, if i double...
I would recommend that you uninstall auto-cad and reinstall it. This is only if you have the CD and a product/serial key. A important file got corrupted when you open the file and possibly edited. the best way to fix the problem is do what i recommended, but then again you mush have the things i specified too.
Oct 03, 2009 | Autodesk AutoCAD 2010
Opening dwgs in autocad
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
I had a cad drawing and I was messing around with it and lost it tried recover and can't recover it. I had someone resend it to me and every time I get it it changes to a file I can't open it is white page...
Most CAD programs such as AutoCad have a history of recently opened files. In AutoCad go to TOOLS/ OPTIONS/ FILES/ Automatic Save location. There you should find a file with the same name but a different file extension such as .BAK (AutoCad back-up) You can set AutoCad to automatically save to any time period, such as every 15 minutes.
Make a copy of this .BAK file so you keep that unchanged, Then change the file extension of the copied .BAK file to .DWG. Then you should be able to open this file. A file with an extension containing the $ symbol needs to be recovered using the programs recovery tool, in FILE/ DRAWING UTILITES/ RECOVER
If you're using a different CAD program look for this backup file wherever the programs Autosave files are set to be stored.
One other possiblity is the file extesnsion is set by your computer to open with another program for some reason. Right click and hit "open with"
Let me know if this helps
Jan 07, 2009 | Computers & Internet
Autocad is not inastall
Vista is 64 bit O/s & your cad is not supported the application & also your cad is not vista verson that,s why it is not working, if you want to use either change the O/s or cad.
Mar 05, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
164 people viewed this question
David Payne
David Payne
