Question about Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x
Tecumseh small engine troubleshooting
Doesn't appear to have any spark
    Top Expert:
  • Tecumseh Master
  • 47,745 Answers
Check point gap---gap to magneto/ fly wheel ---condenser--HT lead. switch wire is not shorted out.
Posted on Apr 25, 2013
Have an old troy bilt tiller, spark plug gap for tecumseh engine
Hi Jesse:
SPARK PLUG AIR GAP ON ALL MODELS IS
.030 (.762MM)
NOTE:
Not all spark plugs have the same heat range or reach. Using an incorrect spark plug can cause severe engine damage or poor performance. Tecumseh uses all three of the reaches shown.
Ta Da!
Mar 13, 2016 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Tecumseh troubleshooting
Three things, the magneto is faulty, the circuit is grounded, the plug wire or boot is faulty. A quick test is to remove the small ground wire from the magneto (usually black), if you then get spark the circuit is grounded by a safety switch or a bad wire segment. If not remove the spark plug rubber boot and remake the connection, if you get spark you've fixed it and if not you need a new magneto.
Jul 29, 2014 | Tecumseh Garden
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
I can't find the serial number on my tecumseh hmsk 110 engine.
as with B&S motors the engine number will be stamped in to the air cowling on the side or above the spark plug
Feb 18, 2013 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
8HP Tecumseh with no spark
Check the gap between the coil and the flywheel. You can fold a dollar bill over a few times (3 or 4 layers thick) , place it against the flywheel , **** the coil up to it , and then tighten down the coil. This will give you a good clearance between the coil and flywheel and promote good spark.
Essentially I am suggesting you use the folded dollar bill to set the coil to flywheel distance/gap.
If it still doesn't work, I am at a loss. Is this a multi cylinder engine ? If so , does it have points or electronic ignition ?
Aug 08, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
The car wont start.
Hello! A few necessary items to successful troubleshooting; What engine is in the vehicle and, since it's a 1996, it has OBDII diagnostics and a Check Engine Light...Is the light on?...If so do you have access to a scanner to find out what trouble code or codes are stored?...Lastly, have you checked for spark? Because your saying it doesn't "seem" to be getting spark...Hate to hit you with a lot of questions but without these particular pieces of information it would be difficult to narrow down...Please add any thing else that seems important...Awaiting your reply...Guru...Saailer
Dec 08, 2011 | 1996 Chevrolet Camaro
No spark on my murry riding lawn mower it has a tecumseh ohv135 replaced the spark plug
clean the flywheel, and the contact area on the coil. if this doesn't fix it then you need a new coil.
Nov 03, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Ariens 8hp Formula rototiller with tecumseh engine- will not start.. have checked spark plug... gas was drained last fall. troubleshooting tips please
well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
May 04, 2010 | Garden
Tecumseh Horizontal Tiller Engine 8 Hp, 1" X 2 57/64" Shaft, Modelno. Hm80 - 155656x Logo
273 people viewed this question
Top Tecumseh Tools & Hardware - Others Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ArcFlash
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Tecumseh Tool and Hardware - Other Expert? Answer questions, earn points and help others
