Router with 3g receiver/ sim slot , ethenet port and wifi receiver ...
SOURCE: unbrick my router by upgrade firmware
Either the router firmware was not for your system or the upgrade didn't take. If it just didn't take, you will have to reinstall the upgrade or reflash the upgrade manually. Your owners manual or the manufacturer's website should provide specific instructions on how to do this. Depending on the router you have you may also be able to access help information from an administrators screen if it is still accessible. http//: 192.168.0.1 or 192.168.1.1 or other predefined address for your brand of router.
SOURCE: 3gs sometimes does not connect to home wifi.wife
Restore your iPhone, the 3Gs has issues that still need ironing out.
SOURCE: iPhone not seeing DNS or Router on certain WiFi systems.
fix =restore ispw 3G firmware that is earlier your present one, from someone like iclarified. try a few untill the wifi connects online.
you can search net to see how to restore to earlier firmware using itunes.
when wifi, hopefully works, update to latest firmware .
I assume your phone is a import, australia, hong kong? not from your current country.
even if it does nt work no harm should be done.
good luck
SOURCE: sim 1 slot appears SIM CARD IS MISSING.
might be some problem with the slot1..in reading sim
If
all else fails, you can reset the router, this different than simply
restarting it. You will need a pin or paperclip to press the reset
button usually found on the back or sometimes on the bottom of router.
PLEASE
NOTE: Resetting the router will delete all current settings including
securtiy and reset them to their factory default settings.
But
this will isloate any issues that may be associated with your current
settings including security. You can reconfigure your router with the
settings you perfer after determining that the issue is with the router
or not.
