Question about Sharp Office Equipment & Supplies
My AL 1566 Sharp multifunctional printer shows me error code L1-00 what will i do?
    Problem Solver:
  • 16 Answers
L1-00 is scanner feed trouble. This normally means the optical or mirror unit is not moving correctly. This could be caused by a disconnected wire or a faulty motor or sensor.
Posted on May 09, 2013
Opelmanz
  • 62 Answers
SOURCE: SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Posted on Nov 02, 2008
early1234
  • 871 Answers
SOURCE: Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Posted on Jan 27, 2008
SOURCE: sharp al-1644 photocopier
Usually CH indicates that one of the doors on the copier is not closed properly, if it is a flashing CH then there is no toner cartridge in the copier or the cartridge is of the wrong type for this machine. A lot of toners for this machine look alike but are not the same for the machine.
Posted on May 26, 2008
sir fixalot
  • 146 Answers
SOURCE: error on sharp copier
That has to do with the laser unit and/or the white shading plate.
First remove the platen glass and clean the white strip on the bottom side. BE CAREFUL FOR THE GRAY OR BLACK LINE ON THE STRIPE IF YOU WIPE IT WITH A SOLVENT AND REMOVE THE LINE YOU ARE DONE.
If the unit is making a whining noise it is probably the laser unit polygon motor.
If the scanner mirror system is hanging or not returning to home position check to see that the scanner lock on the underside of the scanner where the paper comes out is unlocked.
Posted on Jun 06, 2008
SOURCE: Error Code "L" 0n Sharp AL 1540CS
The scanner does not move - I get an "L" code flashing on the readout - please help???
Jeri
Posted on Oct 07, 2008
ERROR SIST. [H2-00]
how do i clear
h2-00 on AL- 1566
Jul 10, 2012 | Sharp AL-1655CS Copier
How do I reset L1-00 error for Sharp AL-1566
You need to remve the copy glass and clean it thoughly.
make sure it has that sticker the glass come with which has the marks for A4,LTR etc.
also the scanner must be in it home position.
but the cardinal thing is for the glass to have it accessory.
Jul 12, 2011 | Sharp AL-1655CS Copier
I have a Sharp Al 1566 Photocopier,Printer,Scanner and it has encountered a problem which is SYSTEM ERROR (H4-00) so how can I fix the problem?
H4-00 = Low heat roller temperature detection. This is usually caused by either a blown heat lamp or a blown thermal fuse.
Sometimes the error can show up for no particular reason. Try resetting using the following sequence:
#,*,C,* (hash, star, clear, star) then enter '14' and then press the start button.
The machine will reboot. If the code comes back you'll need to check the lamp and fuse for continuity (having removed the fuser from the machine first!)
Hope this helps.
Feb 02, 2011 | Sharp AL-1655CS Copier
How do i reset eorr H4-00 for sharp AL-1566
To reset the H4 condition on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
Oct 02, 2010 | Sharp AL-1655CS Copier
Sharp al 1661 cs ..it shows System error(L1-00
I have posted a tip covering this code here on Fixya. Here is the link to it so that you may find a solution for your L1 code.
Good Luck and Thank You for using Fixya.
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
Jun 10, 2010 | Sharp AL-1661CS All-In-One Laser Printer
SEND ME SOFTWARE FOR SHARP PRINTER DIGITAL AL-1566 TO DOWNLOAD PLEASE
I assume you want the print driver - your request is not very specific.
go to this website to download http://www.sharpelectronics.info/Software.aspx
select your product and windows version.
May 01, 2009 | Sharp AL 1631 Copier
Jeri
Oct 04, 2008 | Sharp AL 1631 Copier
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
