Question about Dell Dimension Computers & Internet
Computer will not start up
It shows 3 and 4 on front
    Brigadier General:
  • Dell Master
  • 3,400 Answers
Roger you must give moore information,it's to little
Posted on Apr 22, 2013
I need firng order for Ford ranger 1990 v6 2.9
My info showed this. firing order, 1 4 2 5 3 6.
Mar 01, 2018 | Ford Cars & Trucks
How to connect the power led,power sw,hdd led on e-machine t2240
Apologizes your question hasn't received a solution until now. I have been 'away from my desk' for a while.
The eMachines T2240 desktop pc uses an Intel D845GVSR motherboard.
So let's go to Intel Support for more information, and to the specific product download page for the Intel D845GVSR motherboard,
Intel Desktop Board D845GVSR Product Guides
On this page left-click right on the blue title -
Intel Desktop Board D845GVSR Product Guide (PDF)
This is a PDF file. The computer you are using has Adobe Reader on it which uses PDF files.
After you have downloaded the PDF file go to the top left and hover your mouse cursor on the rectangular icon. (To the left of the Up/Down arrows and Page: )
Hovering your mouse cursor over this icon will briefly reveal -
Toggle Sidebar. Click on this icon.
Now click on the icon to the immediate right of it. (Show Document Outline)
Scroll the Show Document Outline sidebar down until you see the heading - Connecting Internal Headers -
Now click on the heading immediately underneath it -
Connecting the- Front Panel Header -
[The front of your computer is the Front Panel. The area of connecting pins on the motherboard for the Front Panel is the Front Panel Header ]
On Page 11 in the Product Guide we see that S designates the Front Panel Header.
On Page 31 in the Product Guide it shows the Front Panel Header pinout. (The Front Panel Header is designated by C in the illustration)
Again on Page 32, it shows where the Front Panel cables connect to.
In case you are not able to view the Product Guide;
Viewing the motherboard installed in the computer case, the Front Panel Header lays parallel to the bottom of the motherboard, at the Bottom Right.
It is rectangular in shape and has 9 pins.
4 pins along the Top, and 5 pins along the Bottom.
The pins are numbered Even along the Top row;
Starting from the Left side of the Front Panel Header going to the right;
Pins 2, 4, 6,and 8. There is NO Pin 10.
The pins are numbered Odd along the Bottom row;
Starting from the Left going to the right;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the Harddrive Activity LED.
Pin 1 is for the Positive ( + ) wire. Pin 3 for the Ground wire.
In case the HDD LED is dim when the HarDDrive is active, switch the wires around. (Computer off and Anti-Static Precautions used)
B) Pins 5 and 7 are for the Reset switch, IF a Reset switch is used.
Pin 5 is for the Ground wire.
C) Pin 9 is for 5 volt ( + ) power. Not Used.
(Usually the motherboard manufacturer uses this pin to test the motherboard)
D) Pins 2 and 4 are for the Power On LED.
-> Believe Pin 2 is for the Positive ( + ) wire.
If PWR LED is dim when computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
There is No Pin 10.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 13, 2014 | E-Machines Computers & Internet
Fujitsu siemens scenicview b19-3
hi you must disable the main screen in properties section of the display panel then when you start up the computer the screen will not activate until windows has loaded and found and installed the screen drivers after that all should be good to go if you need any further help don't hesitate to contact me :)
Feb 07, 2013 | Fujitsu Siemens Premium Line P19-1 19" LCD...
Replace power button gateway sx 2311
Computer unplugged from power, FOLLOW Anti-Static Precautions.
1) Remove the Side Panel.
Viewing the computer from the Front; the Right Side Panel removes. Remove screw, pull Side Panel to the rear of the computer.
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113140
Click on the large main photo.
There are 9 smaller views shown. 3 across, and 3 rows.
Bottom row, click on the photo in the Middle.
Shows Rear view of computer.
Along the back edge of the Side Panel, is a finger pull handle formed out of the Side Panel. There also looks to be two screws. One above the pull handle, one down towards the bottom.
2) Remove the Front Bezel.
Click on the Middle row/middle photo.
Also look at Middle row, 3rd photo. (Photo all the way to right)
There are 3 Black tab locks, formed out of the plastic of the Front Bezel. One towards the Top, one in the Middle, and one towards the Bottom.
If memory serves these tabs are gently pulled to the outside, to release the Front Bezel. Ease the Top tab out a little, and Middle tab.
Start easing the Front Bezel away from the metal framework, of the computer case, a little. Then release the Bottom tab.
Front Bezel should swing, and then come off.
Not your Gateway model of computer case, but this Gateway model shows the plastic Tabs to release,
http://support.gateway.com/s/CASES/3501975/3501975faq6.shtml
The Power On Button is an assembly. The plastic housing of the Power On Button assembly, has a Power On switch inside.
I gently heat the plastic with a hair dryer, moving the hair dryer back, and forth at it.
Once the tabs of the plastic, of the Power On Button assembly, is softened; then I remove the Power On switch.
I have found this ATX power on switch, fits a LOT of desktop computers,
http://www.directron.com/atxswitch.html
Regards,
joecoolvette
Nov 19, 2012 | Computers & Internet
Motherboard diagram Acer eMachine MB DA061/078L
Hello? Tap, tap on the monitor. What are you reading from?
http://www.ebay.com/itm/Acer-MB-NB107-001-DA061-078L-Motherboard-eMachines-08120-2-780G-AM2-Desktop-/280919767281?pt=Motherboards&hash=item41681f78f1
The area of contact pins on the motherboard, that the main wires go to from the Front panel, is the Front panel header.
Motherboard installed in computer, the Front panel header is at the Bottom/Right.
Two rows of 7 pins in a small black rectangular plastic block.
http://www.ebay.com/itm/Acer-DA061-078L-Motherboard-eMachines-EL1200-X1200-AMD-780G-Socket-AM2-DDR2-/140825131784?pt=Motherboards&hash=item20c9d4fb08
TOP row of pins is numbered EVEN.
BOTTOM row of pins is numbered ODD.
Starting on the LEFT side going towards the Right, TOP row:
Pins 2, 4, 6, 8, (NO 10), 12, and 14. Again, there is NO Pin 10.
Starting on the LEFT side going towards the Right, BOTTOM row;
Pins 1, 3, 5, 7, 9, 11, and 13.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light)
If the HDD LED is dim when the harddrive is active, switch the wires around.
2) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
3) Pins 2 and 4 are for the Power On LED (Light)
If the PWR LED is dim when the computer is on, switch the wires around.
4) Pins 6 and 8 are for the Power On switch.
5) The rest of the pins are N/C. Not Connected.
Don't forget to plug the 4-pin ATX +12 Volt power cable in,
(Top left corner),
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Regards,
joecoolvette
Sep 06, 2012 | Computers & Internet
My 1995 Diamanter will not start
Hi Guys. I took the car to the auto electrician. He says he checked everything and even had the computer tested. I am running a CCA600 battery which he said was putting out 11.6 volts which is not enough to engage the computer. He charged the battery and the car started. That was 3 weeks ago but now, after 3 days of wet weather it again will not fire. I connected the jump start to it but it still will not fire. The battery is showing full charge so I guess its electrical and I need to do some of these other checks.
Jul 15, 2012 | 1995 Mitsubishi Diamante
How does the power switch and led plug up on a GT5428 motherboard?
This is Gateway Support, and Support Documents for the Gateway GT5428 Desktop PC,
http://support.gateway.com/s/pc/R/1009466/1009466nv.shtml
On this page left-click on Components.
Scroll down the page to the heading - Motherboards
Left-click on -
4006158R - Intel (Coryville) 945G Motherboard
Now Left-click on - Product Views
Lastly left-click on -
O - Front Panel Connector
This shows you a photo of the Front Panel header on the motherboard.
A connection on a motherboard is referred to as a Header.
The Front Panel of your computer is the plastic part where the Power On button is.
The Front Panel header on the motherboard is where the wires from the Front Panel connect to.
The above is not to offend you, or insult your intelligence. Just wanted to give you the exact names of the parts you'll be handling.
Looking at your motherboard with the Processor to the top, and the Ram slots to the right, the Front panel header is located in the very bottom right corner.
Looking at the Front Panel header on the motherboard, you will note the different colors.
There are also Pins that stick up out of the Front Panel header.
Every 2 pins is grouped into one color.
The Front Panel header is located parallel to the outside edge of the motherboard.
There are 2 rows of pins.
One row across the top of 5 pins.
One row across the bottom of 5 pins.
The pins are numbered, as well as grouped into colors.
Starting at the Right side, going towards the Left, on the Top row;
Starting at the Right side, going towards the Left, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
Pins 1 and 3 ( Yellow ) are for the Harddrive Activity LED.
The light in the front panel that flashes when the harddrive is actively being used.
Pins 2 and 4 ( Green ) are for the Power On LED.
The light in the front of the computer that shows when the computer is on.
Pins 5 and 7 ( Blue ) are for the Reset switch.
The Reset button on the front of the computer, IF, the computer came with one.
Pins 6 and 8 ( Red ) are for the Power On switch.
The Power On button on the front of the computer.
Pin 9 (Black) is for the +5 Volt power
Pin 10 is not used. (Not connected)
The reason I took you the long way, and did not just provide a link to the Front Panel header, is in case you need more information about your computer.
This way you'll have it.
Feb 26, 2010 | Gateway GT5428 PC Desktop
Ineed the firing order for a 2001 ford expedition 5.4 l v8 engine. I replace the #4 coil pack and plug , but shows misfire on plug 4. I was told the firing order was not typical of other engines.
Firing order is 1-3-7-2-6-5-4-8 Passenger side of engine starting at front and going back is 1-2-3-4 Driver's side starting at front going back is 5-6-7-8.
Jul 05, 2009 | Ford Expedition Cars & Trucks
Computers & Internet Logo
18 people viewed this question
Alun Cox
