I have a Samsung WA7584C1 Toploader. When it spins it knocks against the sides reduced the items and still does it help please
This only happens when the machine starts its spinning cycle when it washes its fine but the minute it starts spinning it knock against the sides
Samsung toploader,WA13U7 does not pump or spin. When manually put on spin only, only the bottom plate spins and not the sides of the drum
firstly if it has water in it at the spin cycle it wont spin,water remaining is due to a blocked or faulty pump it doesnt take much to jam them
Jan 21, 2018 | Samsung Washing Machines
I have a Samsung WA13Vs toploader washing machine after the washing and rinsing cycles it does not spin, please help.
sadly we can only suggest fixes from here . It might be the control board or the motor . only a repairman with the capability of hands on can tell you for sure
Dec 29, 2016 | Samsung Televison & Video
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
LG top loader now has a very load knocking sound and the cycle stops at the spin stage although the readout goes right to the end so you lift the lid and voila wet clothes
Does it knock all the time? Have you tried it empty? Have a look at the springs or shock absorbers,maybe one is broken or the weight attached to the drum, is it secure and properly located? Check for play in the drum bearing by moving the inner drum side to side against the outer (and also listen to see if anything is trapped).
Apr 19, 2014 | Washing Machines
Samsung washing machine wa7584c1 power is on, programming seems fine, push start and nothing happens,except water flows ok, no washing no spinning no draining
hello check the belt first to see if it's come off or snaped if ok then the fault could be the brushes on the motor 2 plastic blocks sit either side of the motor they wear down can cause the motor to stop working they just slide out hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
My Samsung WA75b9 toploader stops when the rinse cycle starts -makes noise but won't rinse or spin!
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 14, 2010 | Samsung SW62ASP Top Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
