Question about Hotpoint Washing Machines
My washer clicks six times when put onto a cycle then the door light flashes continually and it will not start any cycle...any help is greatly recieved thanks.
The door wont unlock once you have selected your cycle but I have manually released the door but cannot get the filter out to clean it says to turn it anticlockwise but the cap wont budge.
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
To
Try washing bedding, towels, undergarments,
contact using the ActivFresh
GETTING STARTED
1. Load your washer.
2. Close the door.
Z_
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
continues.
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Error dl f: door will not lock to start wash
This is obviously a door lock/switch assembly failure. The fault code FdL flashes if the door locking routine fails, after six attempts, to lock the door. You should hear the door lock clicks six times before the fault code flashes. Replacing the door lock/switch assembly is the only viable solution and it's a do-it-yourself repair. You only need a pair of needle-nose pliers to stretch the door gasket retaining hoop and a Phillips-head screwdriver to remove the screws securing the door lock/switch assembly to the front panel. Click on the link below for the detailed instructions on how to replace the door lock/switch assembly.
Replacing the Door Lock/Switch Assembly on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 17, 2011 | Kenmore HE3T Washer
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
Simpson ezi loader washing machine clicks 3 times then the end button lights up without even starting the cycle. does anyone have a solution for this?Solve this problem 1 2 3 4 5 6 7 This is a... Solution...
It sounds like a door switch fault see if the end light and the start/pause light are flashing count the flashes if end flashes 4 times and the start/pause once or maybe more this could be error 41, door switch fault.A door switch would cost about $ 20 but there may still be a problem with the main Programmer.
Good luck.
Apr 27, 2010 | Zanussi FS1455W Front Load Washer
Front load will not lock
are you getting three beeps when trying to start, if so door lock problem
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM 8103/S Problem
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Oct 07, 2007 | Whirlpool AWM6120 Front Load Washer
FLASHING LIGHT(WHIRLPOOL AWM6120 FRONT LOAD WASHER)
Sep 19, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
