Using this Acer computer, and blue lines appeared when I turn on my computer then the colour and the screen resolution got meused up. I tried changing the resolution but no changes are done
    Scholar:
  • 156 Answers
Could be the video chip/ TCP problem.
Posted on Apr 26, 2013
5 Suggested Answers
griffinkec
  • 46 Answers
SOURCE: Blue vertical thin line on Acer Travelmate 2410
It might be the case that the pixels of that line have become dead.This is a monitor malfunctioning and you shud report to your vendor.
Posted on Feb 04, 2008
Pyrhyc
  • 2028 Answers
SOURCE: LIGHT BLUE VERTICAL LINE ON MONITOR
The vertical line is a bad pixel sensor at the edge of the screen, your screen has hundreds of vertical and horizonal pixel sensors. This is an indicator that the screen is going out and need replacing.
Posted on Jul 03, 2008
Kiranbala
  • 91 Answers
SOURCE: Coloured vertical lines down lcd screen
To isolate the issue, i strongly recommend to connect the notebook to the external monitor by VGA port which had BLUE colored on the notebook. So that if it is normal then you need to confirm the issue is with the LCD display.
Posted on Apr 01, 2009
  • 122 Answers
SOURCE: acer aspireone model ZG5 monitor all vertical lines when on.
Hopefully you have a backup of your data. You should check with Acer to find out the cost of repair to decide if it is worth repairing.
Posted on Sep 03, 2009
Testimonial: "Thanks. Kind of thought that would be the case. just hoped it wouldn't be!! Will put that into play. "
ViewSonic VA2226w, horizontal light coloured lines through image regardless of resolution. They get worse when the monitor has been running for a while. Display otherwise working, powers up and down fine...
The lines appearing on the screen have nothing at all to do with the resolution. If the OSD display is correct (when the LCD is not connected to the PC), then the possible issue could be the RAM. Open the PC case and check if you have more than one RAM stick. Try using one RAM at a time and swaping RAM slots to see if the display is shown correctly. Make sure that the PC is turned off and power is disconnected before you remove/ install RAM. Most of the times lines appearing on the screen are due to faulty RAM. I suggest that you may also connect the LCD with some other PC to check if the issue is with the LCD or not.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 18, 2011 | ViewSonic VA2226W LCD Monitor
Black colour displaying become greenish and narrow vertical lines
Most LCD monitors have a default refresh rate of 60 Hz. Older monitors also have limited resolution. Please check your display settings and ensure you're not using a refresh rate higher than 60, or a resolution higher than what it supports. If either one is the case, you're lucky the LCD still works.
Aug 12, 2009 | Computers & Internet
My acer X193w screen went blue and wont show red
I once had that problem, I think you need to make sure that the power supply cable is fitted well and your monitor receives enough power. if its shares the power cable with your CPU try and separate it then restart your computer.
Jun 24, 2009 | Acer X193W LCD Monitor
Distorted colours with photos/pictures
Check your display properties in settings make sure color quality should be 32bits and screen resolutions should be higher atleast 1024X768. If not Try reloading Video driver.
Dec 14, 2008 | Acer Aspire 5050 Notebook
Acer estensa 5620
Might be something wrong with your display settings. Between the Acer logo and Microsoft logo, try pressing F8 about twice per second. A menu appears. Use the arrow keys and choose the one with "VGA-mode" using the enter-key. Wait while the computer boots. Set a compatible display resolution for your display.
Nov 03, 2008 | Acer Aspire 5610 Notebook
How to change the resolution of Acer AL1702Wb 17
On windows XP and earlier :
1. Right Click the desktop
2. Click properties
3. go to settings
4. the resolution slider is there. Try different resolutions untill it looks good.
Feb 21, 2008 | Computers & Internet
After any game, and go back to XP, my monitor go like 8 bit color,have to power down and up
Try useing a different resolution. The native resolution should probable be 1280 x 1024. Try updateing the video drivers.
Nov 23, 2007 | Acer AL1916W 19" LCD Monitor
Screen distorted
Hi its only a guess but it sounds like you might have the screen resolution turned up to high for the monitor to handle.. if you want to give it a try, try this.. Turn Machine off then turn PC on, and keep pressing F8 when u switch it on till the menu appears, Select SAFE MODE Once windows loads it will look a little different in safe mode. right click on the desktop and select properties go into display tab, and change the resolution to 800x600 and hit apply. Restart PC and see if it helps any... All the best & hope it works John
Mar 03, 2007 | Acer Aspire 3610 Notebook
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
