Question about Brother DCP-J125 Colour Inkjet Multifunction Multifunctio
Why my printer dcp j125 paper jam - Brother DCP-J125 Colour Inkjet Multifunction Multifunctio
SOURCE: Paper Jam in Brother DCP-135C - cannot even see the stuck bit!
lift the top lid and ge it out from the top
Posted on Feb 17, 2009
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
n25an
  • 622 Answers
SOURCE: I have a Brother Intellifax 2820 and a Brother DCP
sounds like you have a bad paper tray... contact brothers support to order another one...
Posted on Dec 27, 2009
SOURCE: DCP j125 Inkjet printer stopped printing showing
well, cut the small piece of black tape (or you can use black permanent marker) and then cover the sensor of the cartridge, once the device will ask you to reinstall the cartridge and new system will detect as a new cartridge
Posted on Jul 17, 2011
SOURCE: Just bought Brother Printer dcp-j125,After
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Posted on Sep 30, 2011
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
Nov 23, 2015 | Brother Office Equipment & Supplies
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Oct 29, 2014 | Brother DCP-J125 Colour Inkjet...
DCP-J125 what is "machine error 31"
Paper jam, do a thorough inspection looking for any stuck bits of paper.
Jul 12, 2014 | Brother DCPJ125 All-In-One Inkjet Printer
Unable to init 50
paper jam or some sensor error, try to clean the sensor located at under the pump.
Feb 10, 2014 | Brother DCP-J125 Inkjet Multifunction...
Machine code 5a
a 5a error code means that The machine does not work due to a paper jam or some sensor problem. here is a list of error codes for the dcp-j125 printer.
Error Code Cause Solution 30,31,32,33,34,35,36
37,38,39,3C,3F The machine does not work due to a paper jam. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) 40,42,43,44 The internal temperature is too high. Unplug the machine from the AC outlet and if possible cool the room where the machine is located. 46 The ink absorber pad is full and needs replacing. Please contact Brother Customer Service from "Contact Us". 48 There is a problem on the print head, Please contact Brother Customer Service from "Contact Us". 49 The internal temperature is too low. Unplug the machine from the AC outlet and if possible warm the room where the machine is located. 4F There is a problem on the print head. Please contact Brother Customer Service from "Contact Us". 50,51,52,57,5A,5B,5C
5D,5E The machine does not work due to a paper jam or some sensor problem. Clear the paper jam. (Please refer to "FAQs & Troubleshooting" for information on the Paper Feeding.) If the problem still continues after clearing the paper jam, please contact Brother Customer Service from "Contact Us". 8F There is a problem on the paper feed motor. Please contact Brother Customer Service from "Contact Us". A5,A6,A7,A8,AF There is a problem on the scanner. Please contact Brother Customer Service from "Contact Us". E2,E3 There is a problem on the main PCB. Please contact Brother Customer Service from "Contact Us".
Jan 07, 2014 | Office Equipment & Supplies
Brother DCP-J125 Colour Inkjet Multifunction Multifunctio Logo
26 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
