Question about Samsung LN-T4042H 40 in. LCD HDTV
Samsung adjusting the picture
We recently bought this LCD TV and I messed with the picture setting because my sone was watching baseball and couldn't see the the score and stats listed. Now the picture is way too big and I cannot figure out how to make it fit the screen again. I have tried all the settings! Also does anyone know if you can save the settings? My husband claims the settings keep changing and the picture keeps getting blurry. Thanks!
    Novelist:
  • 135 Answers
I started reading the manual with your question in mind, but I found that the instructions for screen controls take up about 40 pages. I'll just put the URL for the owners manual here instead. That way you'll have all the information you should ever need for making adjustments. ;) http://downloadcenter.samsung.com/content/UM/200705/20070515083727984_BN68-01167A-01L02-0331.pdf
Posted on Aug 04, 2007
SOURCE:
It sometimes makes a static nose and the picture is dark i have tried messing with the color and back light settings and it doesn't do much
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Jan 7, 2010 - 26 posts - ‎15 authors
Hi, I have a Samsung LN40A550 LCD TV which I have had for just over a year. ... I was watching TV yesterday and all of a sudden the picture went all. ... started makinga very high pitched buzzing sound with no picuture coming on. We did have a bunch of green vertical lines, but now just a black screen.
Samsung LCD Green Screen - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - TV hooked up to basic cable and getting green screen picture. ... I was getting green static in the dark areas and green fuzz down the left hand ... where can you find the white ribbion, i have a lg rt-32lz50. it works sometimes, but i goes green. Samsung LCD TV screen went black (audio on, no picture)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
Samsung DLP crackling/static noise
Jun 11, 2015
LCD TV making clicking/cracking sounds
Nov 24, 2006
More results from www.cnet.com
Samsung LCD Loud Noise and Green Vertical lines at Start up ...
www.badcaps.net > ... > Troubleshooting TVs and Video Sources
Feb 03, 2016 | Samsung Ln40e550 40 1080p Lcd Tv ln40e550
Samsung le32r7 tv picture light levels v low
Reverts eventually means there is some looseness some where. Please check connectors and cables between power supply- TCON, TCON- Panel and main board-TCON. If you cant do it show it to some qualified technician.
Dec 20, 2013 | Samsung LN46A550 LCD TV
We recently bought a Samsung 500 Series 46" LCD
make sure you have the aspect ratio set at 16:9.
Mar 23, 2011 | Samsung Televison & Video
My JVC AV-27020 TV that I bought used on craigslist needs videa adjustment. The video needs to be reduced so that the entire pictures fits on the monitor. For example, if I'm watching a baseball game I...
the problem is the vertical height adjustement but usely you dont need to adjust this setting its inside
the set , thats is probably a capacitor in the vertical deflection circuit chips but you can disconnect the set and open it and look for a mini control wheres its write v height because the guy sale you the tv should have a problem with this;i highly recommend that you dont do wath i say but call a tech at home and make it fix its an hour jobs about
its not verry expensive...
hope that will help you ps if you decide to open it and fix that by your self watch you have very high voltage inside it can arm you seriously
regards allan ,pro tech..
Oct 03, 2010 | JVC AV-27020 TV
My Samsung 23 inch LCD tv works fine for 25 minutes then the screem starts jumping..
There is a Anynet Setting under the input tab. It has to be on the right setting or the picture Jumps after 20-25 minute. Once I adjusted it to the right setting it stopped jumping and it now works Perfect. Would nt have figured it out if I wouldnt have been messing around with it as a last chance deal.
Dec 27, 2009 | Samsung LN-R237W 23 in. LCD Television
The picture on my 42 inch LCD Samsung doesn't fit the screen. I can't see the scores for baseball games. I've tried adjusting the picture, but nothing works. Any suggestions?
Check your display size. It sounds to me like you have it set on ZOOM. On your remote there should be a button labeled PICTURE. Scroll through the setting till you see 16x9 and set it to this. Keep in mind that some commercials and programs are not filmed in widescreen so the picture will be in the 4.3 aspect ratio, "square"
Jun 23, 2009 | Samsung PS42P2S 42 in. Plasma Television
TV won't turn off
Problem solved. I opened the configuration menu, went to Setup, More, Light Effect, changed setting from "Always" to "In Watching TV".
Dec 09, 2008 | Samsung LN-T4071F 40 in. LCD HDTV
Reccomended settings for Samsung 52 inch LCD tv
I have recently posted a question regarding my Samsung 52 inch LCD hi def television. After doing some research online and reading some others experiance I have adjusted my settings in the menue of the tv to provide the best picture.
May 30, 2008 | Televison & Video
Picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
Dec 28, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung LN-T4042H 40 in. LCD HDTV Logo
389 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
