Question about Craftsman Garden
Craftsman 32 cc gas trimmer won't start.
I have been using it yesterday and is running well. the following day when i am about to use it again, first I added gas. Then I started it ran few seconds then dies down. Sometimes I switch the choked to full half and off. Sometimes it would run on full or off or half but won't stay long.
Now it won't start at all.
  • 4 Answers
SOURCE: Problem with gas trimmer staying started
That is sooooo right. I had the same problem and after putting the whole machine apart I finally spotted those two screws next to the carbutator, and by adjusting them I managed to get the problem fixed. Note that if the machine turns itself off when you hit the gas, it may be that the air intake or the gas intake are either too open or too close. So, adjust them to your flavor....
Posted on May 28, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Posted on Jul 02, 2008
  • 163 Answers
SOURCE: My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Posted on Jul 05, 2009
  • 71 Answers
SOURCE: stihl line trimmer starts but won't stay running
check to make sure your kill switch is not shorting and you have the right gap from the coil to the flywheel also if the flywheel sheer pin is damaged in the least this will cause a multitude of problems... it is the timing pin and must be in good shape not damaged or sheered ..any way reply to mrdmburns@cableone.net and i will try to help you through this.... DALE good luck and will wait for reply..
Posted on Aug 29, 2009
  • 83 Answers
SOURCE: 32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Posted on Sep 10, 2009
Craftsman tiller won't start unless I manually prime cylinder with gas. There is no primer bulb. Can I retrofit a primer bulb in the gas line?
Hi
You can insert a primer system into your fuel system
Just follow the fuel flow below
Please take time to rate me
Bud
Oct 23, 2012 | Craftsman Garden
Craftsman 32 cc trimmer is 5 years old never tuned it up. Now it will not stay running.
Here is my Tip on this problem:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
If you have already turned the adjusting screws, you may need another one of my Tips.
Just let me know.
Jim
Aug 15, 2011 | Craftsman 25cc Gas Line Trimmer
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
Need gas line sketch for craftsman brush wacker 32.cc
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.58fe8f0.jpg
Apr 26, 2010 | Craftsman 25cc Gas Line Trimmer
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
I have a 32 cc craftsman convertible gas trimmer and I need to know what the tool is called to adjust the carburator?
the tool is Poulan Part Number 530 035560 and can be purchased at http://cgi.ebay.com/POULAN-CRAFTSMAN-HUSKY-CARBURETOR-ADJUSTING-TOOL---NEW_W0QQitemZ280351588986QQcmdZViewItem or just google the part number and you will find it.
Lee
Aug 12, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman 32 cc
theoretically the primer ball is the t connector.
Aug 01, 2009 | Craftsman 25cc Gas Line Trimmer
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32 cc
Your gas cap is probably clogged with dirt. The next time you run the trimmer and it begins to stall out, loosen the gas cap, it should start to run good again. Gas cap must be able to breathe in order for gas to flow properly.
Jim
Jun 04, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
454 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
