Question about Vacuums
The small round filter near the handle is sucking in air and making a noise
  • 57 Answers
It should be damaged if u cannot close it, and it will work like a wistle if you dont fix it, so it will be loud.
fix handle hole, and problem will disappear
Posted on Apr 22, 2013
My Shark Navigator works very well, great suction. However, it is very hard to push on carpet. Can this be adjusted?
Two things make carpet vacing easier. First is the floor piece. It should be a smooth slight rounded shaped piece with just a small line of bristles or none at all. Second is mostly for area rugs is to open the suction vent usually located near the handle. That allows some air in which takes suction away from the floor piece allowing it to slide on the rug rather than drag it around.
May 02, 2015 | Shark Vacuums
The small round filter near the handle is like sucking in air and making a noise
it works like a wistle, close it with a piece of stickytape
Apr 22, 2013 | Vacuums
Loss of suction, sucking air through hole on side of housing. Whats causing this?
The air hole on the side is a secondary air release if the suction is not reaching the dust collector detachable bucket. I had this same problem, if nothing is clogged in the hoses try scrapping all the dust off the cylindar screen filter inside the top of the detachable dust collector, I didnt realize that my filter screen had so much **** on it so I cleaned it off and the vacuum worked like a charm. Now the air can flow through unrestricted.
Mar 03, 2012 | Shark Navigator Bagless Upright Vacuum
Vacuum has lost suction and is making a hissing noise
I had the same problem with my Kompressor.Initially I had cleaned all three removable filters.There is two in the canister that can be washed with dish soap. The HEPA filter is located in a compartment on the lower front side of the vacuum.This HEPA filter should not be washed.I found that tapping it inside a trash can dislodged alot of dust from it. After cleaning all the filters and canister I was having the same hissing noise coming from a small hole near the bottom of the vacuum. Next I removed a hose fitting on the lower back of the vacuum and that is where I found a very large amount of debris clogging up the hose. I used a metal coat
Nov 11, 2011 | LG Kompressor Upright Vertical Cyclone...
When I step on the head so that vaccum enguages it stops sucking. You no longer hear air being sucked through the handle as well, the head does not **** down to the floor. When you lock the handle in the...
near the bottom of the vacume where the hose bends down to the floor sweeper, check to make sure there is no blockage. this is the most common problem with vacume suction. you can use a wire coat hanger to help loosen the dirt and debris from the line and it is sometimes easier to clean properly if you remove the bottom plate ( like you would if you were changing the belt ). also while you are getting dirty and having fun, this is a good time to clean the air filter, ( tap it out good or/and use a brush or air compressor to clear and clean ).
c...
Dec 31, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
The suction in the hose of my 2 year old Dyson Animal vacuum is compromised. I may have sucked up a small cat toy or something. Regular vac still is fine. The hose "sucks closed" after a few seconds near...
Hi there, it sounds as though the wand handle is blocked. To test this, remove the wand handle from the hose and test the suction at the top of the hose. If its strong here, then you will need to remove the blockage from the wand handle. If the suction is still poor, you will need to remove the hose by pressing in the catch on the hose cuff near the base of the machine and removing any blockages.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Dec 28, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
KENMORE pROGRESSIVE WITH DIRECT DRIVE SUCKING NOISE
I had the exact same problem. The port is a relief valve to prevent the motor from burning out if the hose/bag are clogged. Check the main hose from end to end after removing the 3 screws that hold it to the body of the vacuum near the handle. If that's clear then it's almost certainly clogged in the short tube that goes from the beater bar housing to the hose extension (where the flex tube attaches). There are two ways of going about this.
Option 2
(the way I did it) -- Lock the base on the upright position and turn the unit over. Unscrew the 12 or so screws in the black base. You'll need to depress the release pedal when removing the screw at the end of the pedal. Once you have all of the screws removed carefully wiggle the base loose. You do not need to remove it completely to access the short flex tube. Clean it out and replace everything in the opposite order from how you removed it.
Option 1 (what I would do next time) -- Cut a wire coat hanger and make a small 1/2" hook at the end. Bend the straight section into about a 4" radius arc leaving plenty to handle at the end opposite the hook. Carefully snake the hanger down the tube and pull out the giant clump of hair and dirt that's clogging the vacuum.
cheers -- eric
Nov 15, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Accessory hose not sucking
Try taking the hose off, and making sure it is not stopped up, either in the hose, or where it attaches. Straighten a wire coat hanger and run down the hose to check for obstructions.
Hope this helps!!!
chad
Oct 08, 2008 | Dyson DC14 All floors Bagless Upright...
FLexible hose has no suction
It is possible that the hose at the base has deformed under suction and is blocking the airflow. I have found this to be the case on mine. Air is being drawn in from a bypass valve near the base and to the left of the hose so it makes a suction noise but does not have any pull at the nozzle.
Jul 11, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
NOT DISPENSING
Does water squirt out of the hose nozzle, if it does, then check the heater inside the handle asm. Make sure that where the tubes hook up to it are not clogged. If water doesn't squirt, check for the seal at the bottom of the tank, it needs to be on the tank, not in the hole. The flow indictor cap is leaking air or maybe is too tight. If you had the top cover off, make sure that the tubes are routed right so as not to get pinched when the cover is put back on, the smart mix knob should be in the water setting and that the piston is on the bottom of the smart mix knob. Pump is bad. Try running a mix of vinegar and water to see if that unclogs the lines.
Apr 28, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
