Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Brand New Troybilt 2cycle weedeater.Runs great but when I depress the throttle the head does'nt want to spin and motor dies out?
4 Suggested Answers
smartr10U
  • 1305 Answers
SOURCE: weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
Posted on May 28, 2009
Dolfoff
  • 148 Answers
SOURCE: Weedeater Head won't Turn?
If less than a year old, and you can verify such...
Read Troy-Bilt Warranty Policy here.
Click on "GET ANSWERS" under the heading of customer service on the left side of the page.
Posted on Sep 29, 2009
  • 10865 Answers
SOURCE: I have a Troybilt weedeater that works great until
Hello dane. Change the fuel filter, install a new spark plug and a new air filter. Then get a can of carburator cleaner to add to your fuel. let that treated fuel run for 5 minutes and you should have your problem solved. If not, you will have to replace the carburator or rebuild it.
Joe
Thanks for choosing Fixya!
Posted on Mar 21, 2011
Motor starts and runs fine but trimmer heads only spins slowly
replace the centrifugal clutch at the motor end of the unit shaft
Jul 18, 2015 | Troy-Bilt Troybilt Mtd String Trimmer...
Why doesn't the cutting head on Stihl F38 trimmer spin?
Maybe the cutter head has come loose from the shaft. make sure the head is engaged to the drive tube properly
Jul 09, 2014 | Stihl Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Hi i have a echo weed eater. It starts with only a couple of pulls and the runs great and sounds great. when i have the head up in the air it spins rather quickly but when i hit grass the head starts to...
check the cable that runs through the shaft from engine to head, it may be brocken or striped but when theres no pressure on the head it spins ok
Jul 24, 2011 | Garden
2002 kdx 200 reman motor idles great under acceleration and load it runs poorly smokes excessively and fouls sparkplug been running a 50 to 1 ratio of gas oil mix any suggestions
Make sure you have recommended spark plug. 2cycle bikes require a hot plug in order to burn fuel efficiently. I'm not that familiar with your bike but it seems too new-ish for the rings to be bad already. Another thing is... that you can't just use any 2cycle oil... you must use the manufacture's recommended oil for the fuel. Many of these machines are picky about which oil is used. Fuel to air mixture many times is the problem... this has to be just right on a 2cycle... they are touchy if they don't get the right amont of air. I hope somehting here will help you to find the answer or at least eliminate a few things if nothing else :)
Jul 24, 2011 | 2002 kawasaki KDX 200
I have a Troybilt weedeater that works great until I put the tiller attachment on. With the tiller on, it dies after a few minutes of use. Any ideas?
Joe
Mar 21, 2011 | Troy Garden
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
125 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
