Question about Gateway Computers & Internet
Cant get to boot up tried almost everything safe mode launch system repair enen tried to restore what should i try next
    New Friend:
  • 61 Answers
Check the boot settings, it may be trying to boot from another source. make sure primary boot options are the hard drive.
Posted on Apr 24, 2013
5 Suggested Answers
  • 26 Answers
SOURCE: Computer keeps rebooting into safe mode
Try going to system tools, and select system restore .. If that does not work ,May be virus, may have full restore with formating the hard drive
Posted on Mar 26, 2008
  • 148 Answers
SOURCE: Can't restore factory intallations and settings: Vaio VGN-FE880E
Are you doing DESTRUCTIVE recoveries or are you doing NONDESTRUCTIVE recoveries? Try another hard drive in the machine and recover to that. Nondestructive recoveries replace the operating system without destroying the personal data. Its possible the original problem is propagating over to the recovered systems. Do a destructive recovery. Understand any data not backed up will be destroyed. Possible the original problem was a trojan virus.
Posted on Mar 23, 2009
  • 323 Answers
SOURCE: xp wont boot up, gives option of safe mode, safe mode with config, restore last work etc but none of these work? Any ideas
Will it allow you to enter the safe mode? If so, and you can choose help and then restore you can back up to a date before this problem began. It sounds as if the MBR (master boot record) is contaminated.
If you made a set of restore discs when you got the computer, now is the time to use them. If you are lucky enough to have an original Windows disc, you can place that in the CD/DVD and go to the point where it asks if you want a complete install or repair an earlier on. Repair should do it, although it may still ask if you want to repair the MBR.
There are other options too, one of which is using the D: partition on your hard drive which contains restore, to restore your computer to the same state in which you bought it. However, this will lose all your data, and you will only have the programs like when it was brand new. Let me know if none of these work.
Sirwriter
Posted on May 13, 2009
  • 243 Answers
SOURCE: asus x58l launch startup repair doesnt work cant
What is your operating system? If you have Vista press F8 at boot and select Last known good configuration that may work.
Posted on Oct 18, 2009
Tuvaro virus, can't remove.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
If this fails you might have to go back into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service.You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Feb 21, 2014 | Computers & Internet
Switches off after few seconds
Does it work in safe mode ?
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
May 15, 2013 | Acer Aspire Computers & Internet
Hp pavilion will not boot, error0xc0000409
Step 1:
As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials If this fails you might have to go back into safe mode. You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
Feb 03, 2013 | HP Pavilion dv7-1245dx Notebook
I tried normal but it didn't work so I tried safe mode and it din't work The mouse icon stays there then the computer goes off then I click the mouse and it goes back on but the login screen never pop
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart. Hope this helps. if this fails to fix the problem During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution restart back into safe mode you might need to select your operating system to load into safe mode To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Jan 15, 2013 | Computers & Internet
Exception EInvalidPointer in module SysMech.exe at 00061CD
Enable VGA mode
Reboot
Dec 13, 2012 | Iolo Technologies System Mechanic: Windows
My computer was set back to factory setting in safe mode now it wont get to windows
I'll recommend you to insert a windows installation disk or windows repair disk
and then press repair computer, make sure your operating system is listed and press next , then launch startup repair, which will automatically detect for the problem that occured while booting and try to fix it and if this doesn't work try a system restore
Jul 13, 2012 | Dell Computers & Internet
Emachines t5274 vertical blue lines during startup/XP.
It looks like you've got two issues. If you tried a different monitor and it too have vertical blue lines your video card might be bad, but hold that thought. I'm thinking you need to reload the operating system because you can't boot all the way up which is the second issue.
Have you tried to boot up in Safe Mode and do a System Restore? Turn the computer off, then turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Select the Safe Mode option. When it boots, if it boots successfully things will look different in Safe Mode. The screen will be darker and icons bigger, but that's normal. If you get into the desktop successfully, click Start/Programs/Accessories/System Tools/System Restore. Select a restore point (date and time) that is before you started having problems. If the system tells you that you have no restore points, then you will have to either Reload the Operating System or do a System Recovery. By the way, System Restore does not lose your data, documents, music, pictures, videos, or programs unless the program was installed after the restore date. System Recovery LOSES EVERYTHING, it sets your system back to when you first purchased it.
Mar 26, 2012 | eMachines T5274 Desktop PC
Operating system
You have not stated what type of problem you are having??..
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Jan 19, 2012 | Compaq Computers & Internet
My laptop wont go on to the desktop. It keeps telling something about launch start up repair but that aint working
There might be errors in the Windows Opeating System. This might have been caused by the recent hardware and software changes done to the PC. Try booting the computer into "Safe Mode", to do this, turn the pc on and while the computer starts up or right after you press the on button start tapping the "F8" key on your keyboard repeatedly until you see the "Windows Advanced Boot Options". From there select "Safe Mode" then press enter. If the computer boots into Safe Mode, you can try running a "System Restore" to restore the computer back to a date when it was working fine. Safe Mode can be accessed from Start>All Programs>Accessories>System Tools>System Restore. Follow the on screen instructions.
Hope this help. Goodluck!
Mar 27, 2011 | Acer Aspire One Netbook 8.9" Notebook
Problem
If you can boot to safe mode, try doing a restore.
When you turn on the system, just past the POST (before windows loads), hit the F8 key to get the menu between normal boot and safe mode.
When prompted, select SAFE MODE. Don't select safe mode with command prompt, or with networking. Just SAFE MODE.
Use the arrow keys to select SAFE MODE. If you need to log in, do so and proceed to launch windows.
Windows should launch in Safe mode. If it does, proceed to click on START, ALL PROGRAMS, ACCESSORIES, SYSTEM TOOLS, SYSTEM RESTORE.
Select RESTORE MY COMPUTER TO AN EARLIER TIME. Click on NEXT. If you can, select a BOLD date preferably before your issue. Click NEXT. System will load some files, reboot and reload.
If you can't get to safe mode, there may be other problems holding your system up. Did you load anything prior to the messages?
Aug 10, 2008 | IBM ThinkPad T23 2647 Notebook
Computers & Internet Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
