Dell 3010 diagnostic lights 3 and 4
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
Flashing amber light
Hi, on most Dells a flashing amber light on the power button indicates a problem with the PSU or a short on the main power rail, if this is the case you should have 2 flashing lights as well, 1 & 3.
May 05, 2014 | Dell OptiPlex 3010 MT Desktop Computer
OPTIPLEX 3010 KEEP SHUTTING DOWN
Go back to the advanced power settings and check the HDD is not set to turn off after a set time, you can change this to neverto stop this happening.
Apr 03, 2014 | Dell, Inc Dell OptiPlex 3010 - Core i5...
OptiPlex 3010 hdmi audio
You should reinstall your sound driver.
Feb 27, 2014 | Dell, Inc Dell OptiPlex 3010 - Core i5...
No signal from HDMI port Dell optiplex 3010
I'm guessing that you're trying to connect to another CPU screen or a TV via HDMI... This is what you need to do (If you're running Windows 7).
1) Open Control Pannel
2) In the search bar in the upper right hand corner type "Connect to a projector" (Without the quotations)
3) Select the option Connect to a projector
4) A selection box will appear. Select the option that you want.
picture diagram is included below. :-)
Jan 09, 2014 | Dell, Inc Dell OptiPlex 3010 - Core i5...
How do i keep my Dell optiplex 3010 from auto shutting off?
This might be related to the power settings, open the power settings in Control panel, if this is set to Balanced then this will include power down of the HDD, select the change plan settings option and then click the Change advanced power settings, now select the HDD option and set this to never, save the changes and then close the open windows..
Feb 28, 2013 | Dell, Inc Dell OptiPlex 3010 - Core i5...
Dell E510 Diagnostic light 1 is blinking, 2 is out, and 3 & 4 are solid green
those are diagnostic lights which tell a dell tech how to analyze the condition of the motherboard if all four lights are on that indicates a failure more which usually suggest cpu replacement
is your computer doing something odd?
May 24, 2012 | Dell Dimension™ E510 PC Desktop
How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Oct 20, 2008 | Dell 3010cn Laser Printer
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
