Question about Sony MHC-GN1100D REGION FREE MINI SYSTEM 110-220 VOLTS
How can i rectify sony mhc-gn1100d's software freeze?
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: my sony mhc-s9d goes to 'push system protect;
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Posted on May 18, 2011
Sony mhc-gn1100d goes to stanby mode
Check and replace the damaged components at its audio output stage circuit. Short circuit protection is activated now. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/ Type in the brand name of your device in the search box at the top of the display window to get gathered all the related posts. Visit this site too. http://homenol.blogspot.com/
Feb 10, 2017 | Sony Audio Players & Recorders
Stuck on demo/standby mode. How is this fixed?
According to the user manual, with the power turned off, press the display button. Each press should cycle from demo -> off -> clock ->demo
https://data2.manualslib.com/pdf4/95/9481/948024-sony/mhcgn1100d.pdf?48253391a787f4bc09ce1133be0b830c
Mar 26, 2016 | Sony MHC-GN1100D REGION FREE MINI SYSTEM...
How do I connect Optical Audio or HDMI to Sony MHC-GN100D, to have 5.1 & Dolby sound effects?
I guess you are in the same boat as me.
There are Digital (optical) to analog signal converters available. You can use them. I checked on ebay and here are the converts available on ebay India.
http://www.ebay.in/sch/i.html?_trkparms=65%253A1%257C66%253A1%257C39%253A1&rt=nc&_nkw=optical+to+analog+converter&_ipg=200&_trksid=p3286.c0.m14.l1514
Mar 27, 2012 | Audio Players & Recorders
I have lost my remote control of Sony-MHC-GN1100D, Kindly help me from where & what rate I can buy this in mumbai,India,as the sony service centre is hell
Hi
Sony remote controls can be bought from the Authorised Service Centers for Sony, and some of the electronic spare part shops at your town. It will have a model number, usually printed either on its back cover or inside the slip off battery protection lid. If you intend to buy it from service centers, just give the the exact model number of your receiver. They will give you the original one. If you go to buy from local market, give the the model number of the remote control itsef, as I indicated earlier. From open market, you will get Chinese make only. OK.
Jul 15, 2011 | Audio Players & Recorders
Power protect
is' protect 'appears on display?.remove speakers & check again.if then set work without error check speakers & cable. protect appears again there is a problem with power amp module.
Jun 14, 2011 | Sony MHC-RG40 CD Shelf System
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
Dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Jun 01, 2009 | Sony MHC-RV888D Shelf System
What voltage required to power a sony subwoofer
Hey,
I just got one of these units, the SONY SS-WG990.
The RCA cable is direct conection to the speaker.
It requires external AMP.
The other cable is just for the system switch and LED.
If you just have this unit, all you need is an AMP to
feed it.
Apr 12, 2008 | Audio Players & Recorders
Sony MHC-GN1100D REGION FREE MINI SYSTEM 110-220 VOLTS Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
