Question about D-Link DI 514 Wireless Router (DI-514)
Forgot password for router?
Is there a way to obtain the current pasword. All works fine. my laptop access the router, just don't know the password as guests visit for them to use..
  • 41 Answers
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
The defaults are usually Admin for the username and "password", "admin", or blank for the password.
Posted on Mar 12, 2009
Lupa pasword
Here's how to change it:
  1. Go to your Yahoo Account Info page.
  2. Enter your Yahoo ID and password.
  3. Under "Sign-In and Security," click Change your password.
  4. In the fields provided, enter:
  5. Click Save.
Thanks.
TechSupportMart
Feb 24, 2014 | Yahoo Mail
Forgot pasword how to reset
say you forgot your pasword then say that and they will send u a message on your hotmail and youl get your pasword back
Mar 22, 2013 | Computers & Internet
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
Change of router password?
Do you know the current pasword? If not a factory reset is in order but if you do logging into the router is all you need to do. Please elaborate on the router type and wether or not you have the current password.
Jun 07, 2011 | Encore Wireless Router
Can't access the internet,cause of server won't let me connect.
You probably don't have the correct password entered into the wireless network connection. Just obtain the proper password and it should work. Also your computer may not be in range of the wireless router signal you're trying to access. Another possibility is that your wireless card built into the notebook may be faulty. But most likely it's just an incorrect password.
May 05, 2011 | Sylvania G-Netbook
I FORGOT MY PASWORD FOR THE WIRELESS ACESS AND I NEED TO USE THE INTERNET ON MY NEW LAPTOP HOW CAN I MY PASSWORD OR RESET THE PASSWORD
connect your router to computer with ethernet cable.
Then you can access it with following link.
for belkin routers http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.Click on wireless and If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
If you are not able to access your router with above link then RESEt it you can find RESET button in back panel of router press it for 10 seconds.Then all settings are defaults.
Let me know if you need further assistance.
Nov 20, 2009 | NetGear WGT624 108 Mbps 802.11g 4-Port...
Wireless won't recognize the key password
Sounds like you know what your doing but I would just check that
the security method you are using is the same on both the laptop and the router. WPA, WEP, etc.
Good luck
Apr 12, 2009 | D-Link DIR-625 (790069292637) Wireless...
Access to password
yas thats encryprion key it is set for your internet security.
http://192.168.1.1
or http://192.168.0.1
try both this link it is default ip for access router.
but if this ip not works then u must have to reset your router with reset switch it in back side of your router.
thewn u can access router with this link.
then it propmts for user name and password.
then user anme: "admin"
paasword :"admin"
or
reamin pasword blank.
then u got some menu.
go to advanced security then u se encryption code.it is which u prompt when u connect your wi fi internet. ceck those pasword and type wehn u coonect yourinternet .
thats it.
Dec 29, 2008 | NetGear DG834G Router
Forgot password
To ilysurita, cj_mom, top_shutta…
First can I clarify what is meant by a ‘lost password’ …. The original poster here is asking about the password needed to login to the router configuration pages.
If you know the password to login to the router configuration pages, you can still get access to the network key (also known as passphrase, WPA or WEP key, PSK, pre-shared key) – which is the key Windows asks for to connect a new computer to the network. It will be found under a heading like ‘Wireless Security’ or ‘Wireless Settings’ within the router configuration pages. For this model, you can find the router configuration pages by typing www.routerlogin.net (or .com) into a web browser, or http://192.168.0.1
If you don’t know the username/password to login to your router, try using the defaults – for this model, they are admin and password.
However, if the router login username/password has been forgotten, the only way to regain access to the router configuration settings is to reset the router, as described in my posting above. I don’t know of any shortcuts to this one. :(
If you have to resort to this, you might want to wait for whoever set up the router to help with this. This is because resetting the router will remove all your settings – password, network key, ISP connection info – so you will lose your internet connection altogether until it is set up again.
On the other hand, if you’re willing to spend some time and patience, you can have a go yourself.
If you have your original setup CD this may contain a software wizard to walk you through it. If not, you might be able to download a setup wizard from the router manufacturer’s website, along with a quick installation guide (and a manual).
The Netgear site also has very clear troubleshooting and support pages which will help with setup, even if you don’t have any setup software:
http://kbserver.netgear.com/products/wgr614v9.asp
Make sure you use a wired connection. Also, print off all the information you need before you begin, as you will not be able to access the internet while you are setting up the router.
Good luck whatever you decide to do
Dec 21, 2008 | NetGear WGR614 Wireless Router
Forgot security password
Save slight model differences between the different OfficeConnect routers, the procedure to do a factory reset is like this (from memory, for exact details you have to find a manual)
- power off the unit and remove all cables
- connect a normal (straight) network cable between the WAN port and either of the four LAN ports
- power on and wait until the status led is beginning to blink slowly, like 30 seconds
- then power off, reconnect everything and power on again
After this procedure you will have to input all settings from the very beginning, the default password is admin if I recollect correctly.
Jun 06, 2008 | 3Com OfficeConnect Wireless Router
D-Link DI 514 Wireless Router (DI-514) Logo
88 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
