Question about H20 x 5 Mop
X5 mop water keeps streaming out of the pressure release valve and not a lot steam coming out, how can I fix this I have not over filled the tank dont know why it has started doing this, any help appreciated
2 Suggested Answers
app_3rp39393
SOURCE: i need a free manual for my h20 x5 steam mop
Download manual from this link:https://docs.google.com/viewer?a=v&q=cache:5RCXniSxC4MJ:media.thanedirect.com/manuals/h2omopx5-eng.pdf+&hl=en&gl=ca&pid=bl&srcid=ADGEEShf0AFxGS_f29EXdCDW4wZvM1g42aId0uiyL3_tmqKTDkdO4wF_mfSbvY6OmihL7XhmlOGWVW7MZNf2b0vI9DVafGwNmTLwI6YnNbG0vTTqjWTk76S6pK4pxJDRy4l462gV240i&sig=AHIEtbTWo36Y8v6-rk4biMK8NpC-L2S-6A
Posted on Nov 21, 2012
My H20 x5 steam mop keeps tripping the electric I have changed the fuse but this still keeps happening please advise?
Please stop using the mop before you have the thing catch on fire, or even your house/apartment.
What may have happened is the steam/water may have gotten in to the motor some how and is shorting it out.
Jul 11, 2016 | H20 x 5 Mop
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 | Vacuums
Shark steam mop will not syeam grey pruple shark steam mop
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How much water do I put in my shark steam mop??? I got no cup or anything with mine
Just fill the tank...
heatman101
Aug 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop is spilling water out and not steaming.
Empty tank and fill with bottled spring water...
heatman101
Dec 05, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Stopped steaming only releases water into pad
heatman101
ag
Mar 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop will not release water or steam.
heatman101
aa
Feb 22, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop heats up but won't steam. help
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Oct 09, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
H20 x 5 Mop Logo
52 people viewed this question
Top H20 Vacuums Experts
Think Crucial
Think Crucial
Robert A. Watson
Robert A. Watson
Are you a H20 Vacuum Expert? Answer questions, earn points and help others
