Aficio C7521n gives : "Plaats PCU correct kleur"
lolita
  • 385 Answers
SOURCE: Error message says reset PCU correctly
You get this message because the PCU isn't seated properly. This is a link for the user manual for this printer: http://www.ricoh-usa.com/downloads/manuals/printers/cl2000.pdf On page 13 shows a diagram that indicates the photoconductor unit on the printer. Page 60 shows you different error messages, what they mean and how to fix it. It means you have to take out the pcu and reseat it into the printer, it is not in correctly. Page 29 shows you how to do this. It has pictures of how to take out the pcu and put it in correctly. I hope you get it fixed.
Posted on May 12, 2007
  • 37 Answers
SOURCE: Gettin a Error: replace Black PCU.
Hi yes you can fix it yourself it is just a warning that says the black pcu is almost warn out , but if the quality is still good you can clear the message is the sp modes by holding down online and escape whilst switching on the machine , under the menu "engine " is a sub menu called data log enter it and execute pm counter reset
hope this helps
Posted on Nov 16, 2007
drichards
  • 87 Answers
SOURCE: RICOH AFICIO SP C411 DN COLOUR LASER PRINTER
Open the side cover, and unlatch the plate. The PCUs are located in there. In the replacement PCU, there should be instructions.
Posted on Apr 01, 2008
  • 58 Answers
SOURCE: ricoh aficio cl3500n reads replace colr pcu what is this?
The PCU is the photconductor unit. There is a black pcu and a color pcu. Did you replace these or replace the toner cartridges??
http://www.websitetoolbox.com/mb/copierquestions
Posted on Jan 23, 2009
  • 9 Answers
SOURCE: Aficio CL3500N Photo Conductor Unit
If your print outs are clear and the PCU is surely new.
Press Menu
Scroll to Maintenance <Press Enter>
Scroll to Replacmnt Alert <Press Enter>\
Scroll to PCU <Press Enter>
Select Notify Later <Press Enter>
Good luck.
Posted on Apr 06, 2009
How do i fix the error message set pcu correctly on my ricoh aficio sp c811dn
Turn the machine off. Open the access door and remove the cyan photoconductor unit. Check the contact pins are straight and undamaged. Gently reinsert the unit. Turn the power back on. If the machine still does not recognise the pcu is inserted it is probably damaged and needs replacing. How many copies/prints has your machine done?
Nov 05, 2015 | Ricoh Aficio SP C811DN Laser Printer
Aficio MP161 Toner bottle doesn't turn to add toner.
How many copies on that machine? The photoconductor unit on that model only goes 45,000 copies. If the machine wont tone up and the pcu is old i would replace it and calibrate to see if the problem goes away. The pcu is cheap for that model. Start there would be my advice.
Jul 23, 2012 | Ricoh Aficio MP 161 Black and White Copier
I have a ricoh aficio cl7000 and there is a error code black pcu type f - is that the black toner?
No, the PCU is separate from the toner. It is basically the drum imaging unit, and it can easily be replaced if you have a new one. When you open the printer's front door there are a row of black units running diagonally down the front of the copier -- the black PCU is the upper left most one.
You can buy a new black PCU from your local dealer, or else you can find one online from many different sites. Make sure you get the black one -- the color PCUs are separate.
Aug 19, 2011 | Ricoh Aficio CL7000 Laser Printer
Functional problem sc 390 on ricoh photocopier, despite replacing drum, developer,blade,gears. after removing 9 copies it reads functional problem.
SC 390 on an Aficio 1018 will most likely be a bad TD (toner density) sensor, if you've already replaced the drum and developer. (One thing to check quickly though is to pull the PCU out and reinstall it, just to make sure that connection isn't the problem.)
You can either replace the TD sensor by itself, or replace the DV unit (which probably won't be much more expensive). But either way, you'll need to install new developer when you replace the parts.
Aug 17, 2011 | Ricoh Aficio 1018 Printer
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
My Ricoh Aficio SPC811DN printer keeps asking me to replace my PCU colour all the colour carteridges are over half full what do i have to rplace
The PCU is the drum unit. There is one for each colour (C,M,Y & K). Each PCU has a 'life' and the machine will ask you to replace it when it has reached the end of its expected life. The PCU life has nothing to do with the amount of toner that you have in the cartridges and they need to be changed independantly.
Jan 18, 2011 | Ricoh Aficio SP C811DN Laser Printer
How to replace image unit ricoh aficio 220
Do you mean the photoconductor unit? To replace the photoconductor (PCU), open the front cover and the right side covers (the duplex door and the main side door). The PCU sits to the right of the toner bottle -- it is a black unit that has the blue cylindrical drum facing the right side of the copier.
On the upper left side of this unit is a ridged tab. Push this tab in and slide the PCU all the way out of the machine. Open the box with the new PCU and remove all of the tape and paper, then slide the new PCU in where the old one came out of. When you shut all of the covers, the copier will recognize the new PCU.
Apr 23, 2010 | Ricoh Aficio 220 Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
211 people viewed this question
jasbo
jasbo
