Question about NorStar M7310 Corded Phone
Phone won't go to voicemail before 10 rings
My phone won't go to voicemail until at least it rings 10 times. How can I set it to pick up after 4 or 5 rings?
  • kbcapracotta Mar 18, 2009
    How do I get into the cfw programming? The booklet I have doesn't have a code for that.
  • 52 Answers
You have to reprogram this locals cfw no.# of ring .
Go into progaming set type in local step to cfw and # of rings
Posted on Mar 13, 2009
  • terry gormley Mar 21, 2009
    You have to go in to programing. OK
    Press feature ** config (266344) then config (266344) again this will get you in to terminals and sets. You have to find a paper overlay that fits on your phone witch has heading top left back bottom left show top right and next bottom right. Now in programing press the show key and enter the set you wish to cange hit show again and you should be able to go from this to change rings.
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
Extend number of rings before answering machine
The 6041 isn't an answering machine. It will ring until you pick up, an answering machine or voicemail system picks up, or the caller hangs up.
Please refer to the documentation for whatever answering machine or voicemail system you have on your phone line. If you require further assistance, please add a comment to this question and specify the answering machine or voicemail system.
Dec 26, 2013 | Vtech Cordless 6041 Phone
My co-worker's voicemail doesn't pick-up until it rings 12 times. how do we change it?
From his phone, on the intercom, dial *71324 You'll hear a tone and that makes his phone ring 4 times (24 seconds) and forward.
Carl
Aug 24, 2011 | Panasonic KXDT343 Phone
Our DECT2015 phone only rings 4 times and then stops.How cane I adjust the ringing time of our phone? Thanks Peter
Do you have voicemail or an answering machine? This is usually a sign that another device (fax, answering machine or voicemail service) is set to answer the call after 4 rings. You will need to lengthen to number of rings before the service/device in question picks up. (The method to reset this will depend on the service/device that is picking up.) Another possibility is a call forwarding service that is enabled at 4 rings.
I hope this helps. Please write back with details on the device that could be picking up for details on setting the number of rings. If you have voicemail or call forwarding, check with your telephone service provider to lengthen the number of rings before the service kicks in. (There are too many for me to know all of the providers instructions.)
Apr 16, 2011 | Uniden Lands Phones
I want to set the number of rings on my vtech phone for the voicemail to start - like the phone rings 4 times before the voicemail picks up
Since you declined to specify the model of your VTech system, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download a copy of the manual.
Feb 24, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Why does it ring for such a short amount of time?
Do you have it in voicemail mode? Is voicemail set for short rings? Usually between 4 - 10 rings. It may be that it's set to 4ish rings.
I know nothing about this phone so the above is a stab in the dark.
Apr 29, 2010 | Motorola Mobility i580 Cellular Phone
I want to change the # of times the phone rings before voicemail picks up.
You didn't post the model of your phone, but this might work.
- Press MENU/CLOCK on the base.
- Press MENU/CLOCK repeatedly to select RING TIME.
- Press VOL/SELECT to set the number of rings at 2, 4, or 6.
- Press SET to save the setting.
If this doesn't work on your phone please post your exact model number and we'll get the specifics for it.
Dec 12, 2009 | Uniden 2.4 GHz Cordless Phone System
Incoming calls ring 3 times at main extension, then phone stops ringing at main & rolls over to ring at all other phones. Phone rings once at those extensions before going to voicemail. (We have...
Your voicemail thinks that it is ringing six times. The time that it takes to transfer to the extensions counts. Whiloe it seems that there is a lapse the system actually is using enough time to ring six times total. If you need longer ring time at the extension, take in account the transfer time and set it to pick up after 8 or 9 rings. It will actually only ring six. You just have to trick the system a little.
Jul 22, 2009 | Cell Phones
NorStar M7310 Corded Phone Logo
600 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
