Question about Brother MFC Office Equipment & Supplies
How do I borderless print on a Brother MFC 9460 CDN?
I can borderless print to my Brother MFC 9460 CDN. I have put the border on excel to 0 but this have not work. Please can you help?
  • 162 Answers
SOURCE: borderless printing brother HL- 4040cn
This model can't suppor boderless printing. check this for details.
Basic Specifications Printer Type Laser/LED - Color Form Factor Desktop Color Yes Print Technology Single-pass electrophotographic laser Resolution Black Maximum Resolution, Plain 2400 x 600 dpi Speed First Page Out, seconds 16 Black Print Speed (Draft) 21 ppm Controller Specifications Processor Speed 300MHz Memory, standard 64MB Memory, maximum 576MB Languages PCL6, BR-Script3 Fonts Supported PCL: 66 scalable fonts, 12 bitmap, 13 bar codes
BR-Script3: 66 scalable fonts Special Features Borderless Printing No Automatic two-sided Printing Yes Direct CD / DVD Printing Support No Paper & Media Handling Paper trays, std. 2 Paper Input Tray1 Capacity, sheets 50 Paper Input Tray2 Capacity, sheets 250 Paper Output Bin Capacity, sheets 150 Recommended monthly volume, pages 35000 Paper Types Plain paper, bond, envelopes, labels Supported Paper Sizes Letter, Legal, Exec, A4, A5, A6, B5, B6; Envelopes: Com 10, DL Connectivity Interface(s) 10/100 Base-TX Ethernet, Hi-Speed USB 2.0, USB Direct Interface, 802.11b/g Wireless, IEEE1284 Parallel Network Ready Yes Security Features Wireless Network Security: WEP, WPA/WPA2-PSK (TKIP/AES), LEAP (CKIP), SecureEasySetup Software Details Utilities Interactive Help, Driver Deployment Wizard Windows OS Compatibility List Windows Vista/XP/XP Professional x64/2000, Windows Server 2003/2003 x64 Mac OS Compatibility List Mac OS X 10.2.4 or greater Front Panel Display Yes Physical Details Width, inches 16.5 Height, inches 12.5 Depth, inches 18.7 Weight, lbs 64.2 Additional Details Additional Details - Time to First Page: Less than 16 sec (black)/17 sec. (color)
- Optional Paper Input: Up to 800-sheet total capacity via 500-sheet paper tray
- Multi-Protocol Support: TCP/IP (ARP, RARP, BOOTP, DHCP, APIPA (Auto IP), WINS, NetBIOS name resolution, DNS Resolver, mDNS, LPR/LPD, Custom Raw Port/Port 9100, SMB Print, IPP, IPPS, FTP Server, SSL/TLS, POP before SMTP, SMTP-AUTH, TELNET, SNMPv1, HTTP/HTTPS server, TFTP client and server, SMTP Client, APOP, LLTD responder), Apple’s Simple Network Configuration for OS X 10.2.4 or greater, TCP/IP: IPv6
- Network Management Tools: BRAdmin Light, Web-based Management, BRAdmin Professional, Web-BRAdmin
- Linux OS Support: Red Hat, Mandrake, SuSE, Debian PostScript3 PPD
- Power Requirements: 120 VAC +/- 10% 50/60 Hz
- Energy Star Compliant: Yes
Posted on Nov 24, 2008
latcarf
SOURCE: MP600 with Mac OS X - no borderless printing option?
I had the same question. I found the answer at Canon's site but I can't link directly to the page so here's how I found the solution...
1. Go to the Canon Support site. 2. In the "Please enter your question field" type: How do I Print edge to edge? 3. Hit the "Search" button. 4. Click the #1 (top) search result "How do I Print edge to edge?" 5. Click the #1 (top) solution: "Use Borderless Printing (Mac OS X) MP600 6. Follow the directions.
It seems the main thing you need to do is go to the "Page Setup" dialog. Then make sure you've chosen the MP600 in the "Format for:" popup menu. Finally, in the "Paper Size:" popup, select "A4" then "A4 (borderless). It's a hierarchical menu.
FWIW I still haven't gotten a "perfect" borderless print. Seems you gotta get the paper in there exactly straight...
Posted on Mar 10, 2009
SOURCE: HP C4480 Won't Print Borderless
I have hp photosmarrt c4280 printer. 4X6 photo print creating border on the right when printing directly from memory card. Creates border on the top and on the right when printing from HP Image Zone. Any suggestions?
Posted on Sep 18, 2009
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Posted on Mar 02, 2010
I have tiny black dots printing on all documents from my Brother MFC 9460. How can I fix this?
It sounds like the toner cartridge is spitting toner onto the drum. try another toner.
Jun 02, 2011 | Brother MFC9460CDN AllInOne Laser Printer
How do i print borderless
edit ur word or excel file setting board less and u can print bordless
Apr 06, 2010 | Brother MFC9450CDN Colour Laser MFC...
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
Can't find program for borderless printing
You need to really defining "Border-less Printing". Are you speaking of printing border-less photos? Or do you mean border-less documents.
Border less photos are usually set up in the printer's driver, providing that the printer's hardware allows this function. Some printers, especially older models, cannot print to the edge of a page by design.
Don
Aug 16, 2009 | Brother MFC 6490CW InkJet Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Brother MFC 210C Printing slow
You may have already tried but /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} From page 129 of the manual: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000222/MFC-210C_UsaEngUsr_B.pdf
Changing the printer driver setting may improve the print speed.
Highest resolution needs longer data processing, transfer and printing
time. Try the other settings of quality in the printer driver ‘Basic’ tab.
Also, click the ‘Settings’ tab, and make sure you uncheck the
True2Life®.
Borderless printing is slower than normal printing. If you want to print
more quickly, set the Borderless feature off.
Aug 30, 2008 | Brother MFC 210C All-In-One InkJet Printer
White border when printing
It is impossible to do borderless printer from a toner based printer because the printer needs a spot on the page to grab it into the fusing section.
If you need to do borderless an ink jet based printer can provide that for you.
Jul 31, 2008 | Xerox Phaser 8200 Laser Printer
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
143 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
