Question about IBM ThinkPad T41 Notebook
T40 with a key I need to re-assemble.
The key came off the keypad and now its in 4 pieces and I don't know how to put it back on. Please help!
  • mwehry Mar 12, 2009
    That was particularly unhelpful
This install guide might help:
http://www.wildcrazyfun.com/keys/install-blue-green.pdf
Posted on Apr 23, 2009
    Problem Solver:
  • 18 Answers
Okay, here's what you do:
1) kill yourself.
Posted on Mar 12, 2009
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...
If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.
1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.
2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose.
3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up.
4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.
Regards
Jul 01, 2013 | Samsung NP-N145-JP02US NETBOOK
Some keys don't work
Yes! the whole keypad control board will need to be replaced.
May 17, 2012 | KitchenAid KHMS155L Microwave Oven
The green and red keys on Verifone Omni 3750 don't function. I tried to clean the keypad with compressed air spray, but it didn't help. I would like to replace the keypad but I need instructions....
Replacing the keypad is pretty easy if you can find the part. Just take all the screws out, slide out the modem, and pop off the back cover. Then loosen the circuitry underneath the back cover. If you just wiggle it around gently, it will become loose enough for you to slide it over and remove the keypad. It's not connected to anything, it will just come right out and you can put in the new one.
HOWEVER - if your keys are not working, it's probably not the keypad. The keypad is just a piece of rubber. It's probably the contact that the rubber is pressing on. You will most likely need to send it in somewhere for repair.
Jul 18, 2011 | VeriFone VX570 Credit Card Terminal (Dual...
Hello, i don't know how i did it... it might because i was using my laptop keypad(mouse) the wrong way.. but all of sudden it's not working.. i couldn't move the cursor with it.. but i could...
Hi
you could try doing this press the FN+F7 keys both at the same time leaving a few seconds
for it to either enable or disable and if this does not work then please press it again to put back to how it was
many thanks
Jul 11, 2011 | Computers & Internet
My T40 will not connect to my wireless network at home. I don't know what to do, please help.
Make sure the wireless card driver is installed and working.
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Jun 12, 2011 | IBM ThinkPad T40 2373 Notebook
Batteries weak
Hi, Don't know the make and model of your safe but this advice works for sentry safes,if it doesn't help you get back to me with a make and model: If you need to know how to put batteries in, Turn the electronic lock clockwise ( to the right) from the 12 o'clock position to the 2 o'clock position which opens it so you can put in 4 fresh AA batteries replace the assembly by turning it to the left from the 2 o'clock back to the 12 o'clock. enter your combination and check for the green light. Good Luck!
Feb 08, 2009 | Safe International Digital Electronic Safe...
Sears Craftsman Sprocket replacement procedure
You need a gear kit. Amazon sells them. I got mine at a Sears Service center. Beware that you will need to completely disassemble your unit to replace the gears.
http://www.amazon.com/Sears-Craftsman-Liftmaster-Garage-Opener/dp/B000JGLX9C
Mar 31, 2008 | Sears Craftsman LiftMaster Chamberlain...
IBM ThinkPad T41 Notebook Logo
117 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
