Question about Lenovo ThinkPad T61 Notebook
Can't get full screen on my lenovo t61
Small screen is fine and playing dvds in full screen isn't a problem either however,if I'm watching a video on youtube or streaming something and go full screen it immediately slows down or stops and doesn't have the capacity to play the video well at all,click back to small screen and everything is fine. How can I get full screen without this problem??
SOURCE: T61 video lag/skip
have you got the right video codecs
Posted on Nov 14, 2007
SOURCE: won't recognize CDs or DVDs
You should probably download drivers on the lenovo website. Try all of em. make sure u download ur computer drivers.
this is the lenovo website for T61:
http://www-307.ibm.com/pc/support/site.wss/MIGR-67853.html
Note: You can only download these drivers by using only ur T61.
Posted on Mar 10, 2009
  • 26 Answers
SOURCE: Horizontal lines in avi/divx files lenovo t61
Sounds like video codecs problem.
There are to ways to go:
1. (The better in my opinion): forget Winamp and Windows media player, and use Smplayer instead, which uses it's own codecs (and better in all possible ways). You can download it from here.
2. If you'd like to stick with Winamp or Media player, then uninstall any video codecs (not drivers!) from your computer (if there's any), then download and install a proper codec pack, for example: K-lite codecpack (basic is enough) from here.
Hope this helps.
Posted on Jun 11, 2009
Geekman
  • 32281 Answers
SOURCE: lenovo t61 shut down w/out warning. Could it be
When the laptop is conected to the mains adapter and it shuts down for no reseason and you can boot up again after a period, it would indicate that you could have an overheating problem.
Check the fan to see if it spins freely and there are no dust clogging the fan and heatsink assemble, remove and vacuum the dust, if the fan is faulty, replace it.
Posted on Jun 18, 2009
  • 1584 Answers
SOURCE: i have t61 lenovo laptop. frm yesterday the left
Highly suspect faulty mobo.
You can always buy / use ext mouse.
Posted on Dec 22, 2009
LCD backlight replacement
If the LCD screen on your IBM laptop is going dim, chances are the backlight is breaking down. The good news is that if you don't want to spend the money to have a technician replace it, you can do it yourself. There's no need to open up the main body of the computer, but you will have to get into the screen to do the work. Here's how.
Power off your IBM and remove the battery. Remove the nine screws (three on each side) on the side of the screen. Once the screws are removed, the plastic bezel (screen guard) can be removed. Pop the bezel out, exposing all of the LCD screen. Pull the LCD screen gently away from the computer by the corner. Be mindful that the screen is still connected to the computer by a ribbon cable. Remove the tape over the ribbon cable where it connects to the screen and gently pull the cable to disconnect it. Turn the LCD facedown, and remove the piece of tape that holds the top metallic foil against the back of the LCD. Lift the metallic foil to expose the backlight. Remove the single screw at the end of it that holds it in place. Unclip the wire at the end of the backlight from the inverter (power source to the backlight), and remove it from the LCD. Replace it with the new backlight (available at any electronics store or online). Be sure the new backlight is compatible with your particular IBM model. Reassemble the computer reversing the order in which you took it apart.
Remontage / reassembly Lenovo Thinkpad T60 ou T61 all versions http://www.youtube.com/watch?v=dxNB3sxUfos ThinkPad Back Light Replacement http://www.youtube.com/watch?v=tr_trXGEYT4 IBM lenovo T61 display problem http://www.youtube.com/watch?v=Em6XBA_nOZ4
Feb 05, 2013 | IBM Lenovo ThinkPad T61 Notebook
My lenovo t61 screen is cloudy white
definitely hardware sounds like yo have a disconnected LCD cable or most likely its a bad lcd screen
Jan 01, 2013 | IBM Lenovo ThinkPad T61 Notebook
White line on LCD on lenovo t61
Is it there before it gets into windows? If so then it's the screen. You can probably find a replacement on ebay. If not then it's probably the video card. In this case you'll have to replace the motherboard.
Oct 30, 2012 | Computers & Internet
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
Keyboard freezes up, it won't type on ThinkPad T61
Do a full scan with your antivirus, if okay! try a system restore by taking computer back in time before this became a issue.
Apr 07, 2012 | Lenovo ThinkPad X200 - Intel Centrino 2...
How do I brighten the monitor on my lenovo T61?
I believe the T61 is like my T60.
The "Home" and "End" keys will act to brighten or dim the screen when you hit them as you hold down the "Ctrl" key.
Dec 20, 2010 | Lenovo ThinkPad T61 Notebook
Screen goes fuzzy when i play games but dvds work.
It's a problem with the GPU. You should contact Microsoft for support.
Nov 21, 2009 | Microsoft Xbox 360 Console
Broken Screen of my laptop Levono
There are a lot of screens on eBay. Type in "T61 screen" in the eBay search, and a whole list of them will pop up. eBay is normally cheapest. Screens can be easily swapped out with a small Phillips screw driver, and normally takes about 10 minutes.
Oct 26, 2009 | Lenovo ThinkPad T61 Notebook
Won't recognize CDs or DVDs
Mar 09, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo ThinkPad T61 Notebook Logo
83 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
