What does F23 mean on a Whirlpool Sports WFS1274CD front loading washing machine
I am getting F23 during a washing cycle. A reset of the machine and re-start of the cycle results in a normal wash.
  • 1462 Answers
SOURCE: Whirlpool washing machine
check that the machine ramps up to spin speed reasonably and distributes the clothes- ie doesn't spring straight up to spin speed. if this is ok then the fault may well be the shock absorbers located at the bottom of the machine and going from base to tub. check also that the counterweights are intact
Posted on May 09, 2007
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Posted on Sep 11, 2008
s_4u_11
  • 535 Answers
SOURCE: Whirlpool Cabrio High Efficiency Top-Loading
PROBLEM RESOLVED!!!
The best I could find by scouring the internet was that it was a communication problem between the central control unit and the electronic control box. I was getting F1 codes that would stop the wash, then diagnostics showed F68 and F41 codes.
Sears wanted to charge $65 just to come out and diagnose it themselves, and these appliance sites wanted to charge their own fees to offer solutions. So I took a chance and ordered a new electronic control box ($146.00 + S&H) and installed it myself.
There are three long screws behind the control unit "hood", in the back-top of the washer, facing straight up and down. After unscrewing, I lifted up the hood up and forward, and there was a black box - the electronic control. First, you should check all the wires and make sure the connections are ok. If that still doesn't fix it, unplug all the wires, and take the electronic control out by unscrewing one 1/4" bolt. Put the new one in and re-wire everything (it shows what wires go where on the electronic control box - named by colors). No more error codes!
This washer is only a year and a half old as well, I guess it will pobably be my last Kenmore/Whirlp
Posted on Sep 16, 2008
MNTECH
  • 1543 Answers
SOURCE: Visible water level in front-load clothes washing machine?
Yes, it is normal. There is water in the machine. One of the big draws for this style machine is that they use much less water than top load machines. If you stopped the cycle and opened the door, dug down in the clothes, you would find water. The machine fills a small amount of water (below the level of the door) and tumbles. As the water is absorbed by the clothing, the water level drops, so the machine adds more to maintain the water level. This is basically how the washer figures out how big your clothes load is and how much water that load needs. (Of course most sales persons at the big box stores and Sears have no idea how this works)
If you'd like, try running a cycle with no clothes to see how much water is in the machine. (It's not a lot) Now remember this: Because there is so much less water use than a top load machine, you must cut way way way back on the amount of soap and fabric softener used. Use no more than one tablespoon of HE (High Efficiency) soap (even less if it is 2x or 3x concentrate) and one teaspoon of fabric softener per load !!!!!
This should be a Fix-Ya for your question. Thanks.
Posted on Dec 14, 2008
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
What is a flashing F23 Error
blank.gif F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
Resetting the program may clear this error but unlikely.
  • Check the pressure switch or sensor for operation and electrically
  • Check the wiring from the main electronic control card to the level sensor
  • Check all connectors between the main controller and pressure switch
  • Run test program
  • Also see F08 and F12 as heater failure can cause this error to occur
Nov 12, 2014 | Whirlpool Duet Steam WFW9700V Front Load...
Whirlpool F23 code error
f23-whirlpool-washing-machine-error-code.jpg F23 Pressure switch failure Should the main electronic control unit detect that the wash level contact (or level) is on and the switch level for wash heater safety is off for any more than ten seconds during a wash this error code will be displayed.
  • Run test program
Aug 31, 2014 | Washing Machines
7.5 Kg Front Load Sports Washer WFS1274CD Door is locked, how do I unlock it.
Remove the top cover, located the door latch. On the bottom of the latch is a release for the door. Simply pull this down and the door will open.
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool Washing Machines
In the middle of a load my washer will stop and starts flashing F23? It is a whirlpool duet steam.
Hi, F23 means that there is a fault in the heating circuit and the heater is not working This fault is triggered if the water fails to rise by 30C or 86F in the first 8 minutes of the heating process.
1. Unplug washer or disconnect power.
2. Check the connections to water heater.
3. Check resistance and continuity of the heating element.
4. Check the water temperature sensor and connections to it.
5. Check the water temperature sensor and connection to it.
Oct 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
Whirlpool 6th sense front load washing machine stopping mid cycle. Have to turn power off to reset & restart
I have the same problem. Stops randomly during the cycle and turning off the power for a second re-starts it.
I think it is one of the sensors is faulty - for example the sensor that detects if the load is un-balanced, or if the machine has enough water.
Seems to be a common poblem for these machines.
I'm going to try to find which one later today.
Dec 20, 2009 | Whirlpool AWM6120 Front Load Washer
On whirlpool duet ,am getting fault code f21 in wash cycle.
Foreign objects in the prepump
remove access panel in front remove round plastic plug clear objects have towels ready
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F23 fault
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Oct 25, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
